Monitor Passive radiator repair
I all, Is there any one that repairs rubber surrounds on passive radiators?
thanks
  • soundfreak1
    soundfreak1 Posts: 3,414
    Which ones, may be able to pick them up here on the club cheeper than replacing surrounds
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • cortico
    cortico Posts: 587
    edited June 2015
    The 8" passive radiator sw80, I believe. I got a reserve set on ebay that is showing some signs of dry rot.
    F1nut Posts: 51,703
    There is no fixing that.
  • westmassguy
    westmassguy Posts: 6,850
    edited June 2015
    Contact the seller and get your money back. Replacing Rubber Surrounds is a Royal PITA. Unless you have the exact thickness, and know the exact type of rubber compound that was used originally, the T/S parameters can change dramatically, rendering the PR useless.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • cortico
    cortico Posts: 587
    Interesting, I have compared 3 different 8" passive radiators and observed that they are different.
    Not sure if I am using the correct vocabulary, The older set has a thicker rubber surround, paper cone with coated fabric on the exterior. The other has a noticeable thinner surround, fabric cone with coated fabric on exterior?! The third looks the same as second but has a paper cone...
    They all seem to be original with no kids...
  • soundfreak1
    The surrounds and cones will be different between models and production years but should not vary within the same pair of speakers. If replaced it should be with surrounds of simular specs ie flexibility, density on the rubber and movement of the cone. If you use the incorrect one that can alter the sound dramatically. And ruin the speakers
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • cortico
    cortico Posts: 587
    thanks, they all came from m5, for some reason, I prefer the sound is the set with the fabric cone...
