Rotel remote codes
cdn5003
Hey guys
Picked up a Rotel RX-950AX without remote control recently and was wondering if anyone knows where I can find the remote codes for Rotel.
Also what universal remote would be good to get to use with this. Hoping to find a solution that isn't too expensive. Really just volume up and down is all I need
HT Setup: Onkyo 706; Rotel RB-1075; Rti A3; Csi A6; Fxi3's
2 CH: Squeezebox Touch; Dared SL-2000a; GoldenEar Triton 5 or Lsi9's; Parasound 2125; SVS SB12-NSD; Music Hall DAC 25.2
PM me with your email I can send you the codes for this in crestron IR+.
Or look at your phone, do you use an adroid?
If you have a old iPhone you could buy a L5 IR blaster.
Here is a replacement
http://www.remotes.com/product-p/rotel rtrr939.htm
Post edited by RamZet onB&W CM9Classé Sigma
