Interconnect cable
I am getting ready to put together my interconnect cable on my SDA 1's. I have my cable and Neutrik Speakon connectors ready. I have noticed in the "Handbook" that pin 1 different on the left and right speakers. What should I be watching out for as I wire these up? My speaker connection is two pins with a hole below them.
  • gimpod
    gimpod Posts: 1,793
    As long as you wire your cable straight through i.e. + to + and - to - you should be fine. The important part is especially if your SDA 1's are blade/blade or the original 3 pin connector is the wire that go's to pin 1 (it will be a different color depending on which speaker left or right), I would connect which ever color wire go's to pin 1 to the + pin on the Neutrik Speakon connector that your putting in your speaker.
    Hope this helps and makes sense.
  • Flathead38
    Flathead38 Posts: 72
    Thanks, that does make sense!
    I appreciate your help.
