Polk Audio SDA-2B w/ Monster cable - matched w/ Technics SA-DX940 receiver - QUESTION ON NEXT MOVE
Hey guys, first time poster. This is my setup as titled. I purchased everything for $150. I'm well aware that the SDA's are being quite underpowered. I can start to hear the mid's become distorted at around half way up in volume, on my Technics receiver.
I really think I would be very happy for now, with about 2x - 3x the power, but unfortunately it won't be easy, as the Technics receiver has no pre-out's for a Power Amp. How can I most cost effectively increase power 2x-3x?
Should I find a similar receiver, but one that has pre-outs, and then mate a power amp? If so does anyone have a suggestion or more?
-So I want 2x-3x the power
-The receiver/amp should be "common ground" (?)
-I want a receiver that is as least as modern as the Technics I have already...
-I want an efficient setup- no wasted channels/power
-The receiver/Power Amp only need power these two SDA's
-...I know there are a couple more mods some suggest for these SDA's (i.e. tweeters/crossover) but for now I want to bring some juice
Sorry for any newbie-ness...I'm somewhat car audio savy, but very new to Home Theatre
[img][/img]Polk%20Audio%20SDA-2%20%20%20amp%20Technics%20SA-DX940_zpsrfr8ppgh.jpg
Best Answer
  • Schurkey
    Schurkey Posts: 2,125
    Answer ✓
    You cannot use the Ashly when bridged. You MIGHT be able to use it in stereo mode. The owner's manual doesn't provide details on whether it's common-ground in stereo mode (that I found, anyway).
    In general, pro audio doesn't get a lot of enthusiasm around here.
Answers
  • vmaxer
    vmaxer Posts: 5,122
    edited May 2015
    Great deal on the setup. Did you get the interconnect cable?? (Runs from speaker to speaker only)
    I have a few sets of SDA's, in my opinion they are hard to beat when set up and powered correctly.
    I have ran a receiver to an amp and really liked it until I got a separate pre. It may have been the receiver I had though?? Lots of choices out there.
    I would also step up a bit on cables, you don't have to spend a fortune to get improvements. (This will certainly start a debate on cables) I apologize for that up front.
    Hopefully others will chime in and help.
    Welcome to the forum and congratulations on being in the SDA family!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • JNinja
    JNinja Posts: 100
    Thanks a lot! Yes it has a monster cable SDA interconnect
    gudnoyez Posts: 8,213
    First off welcome to the forum, great deal on those 2B Studios, so you want to use them as fronts as part as a HT set up is that correct? If so you would need an AVR with preouts and an external amp that's common ground. I would be easy on the volume with that Technics as to not underpower those SDA's.
    I would prefer to use them as part of a 2 channel system for music only myself, perhaps there is someone amongst us that uses SDA's in a HT set up that will give you some advice. Did you get the interconnect cable with them? Make sure you give them some space between them do a search on SDA placement. Enjoy them and be easy on them until you get some power behind them.
  • vmaxer
    vmaxer Posts: 5,122
    Go to this site ( this guy is a member here) you can download the SDA handbooks which have a lot of info on SDA's.
    Not sure if you want to upgrade them at this point but maybe in the future.
    Warning, we will help drain your wallet B)
    http://vr3mods.com/site/bf4e7f6714364a4bacad04f486805b0a/default?url=http://vr3mods.com/LCSDAUpgrade.php#2549
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,122
    Also, don't drive them to distortion, you can do a lot of damage, underpowered is much worse than way too much power.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • JNinja
    JNinja Posts: 100
    gudnoyez wrote: »
    Yes I think I'm just looking to make a 2-channel stereo for music...I'll also listen to movies with them, but no reason in my mind that that won't be good with it set up as a 2-ch ....
    I'm not pushing them hard, and yes monster cable is present
  • JNinja
    JNinja Posts: 100
    vmaxer wrote: »
    Thank you, the site is not working though
  • JNinja
    JNinja Posts: 100
    Never mind, I figured out how to break down the site to type in
  • JNinja
    JNinja Posts: 100
    Thanks for the suggestions information so far, but again, can anyone suggest a proper Receiver and/or power amp ?
  • vmaxer
    vmaxer Posts: 5,122
    JNinja wrote: »
    If you are looking for an inexpensive amp, look into an older Parasound. They work great with SDA's. Also there is an Adcom GFA555 for sale here that would work very well.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ken brydson
    ken brydson Posts: 9,097
    vmaxer wrote: »
    JNinja wrote: »
    'cept he has 6 posts and can't buy here...
  • vmaxer
    vmaxer Posts: 5,122
    vmaxer wrote: »
    JNinja wrote: »
    Sorry, I didn't look at that. Maybe try some of the other sales sights.
    Good luck.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • JNinja
    JNinja Posts: 100
    Thanks for the AMP suggestions. That Adcom seems like a beast! I can't even consider one until I find a receiver with pre-outs, common ground, and again I'd like something as modern or more than my current Technics. Thanks!
  • vmaxer
    vmaxer Posts: 5,122
    The pre doesn't have to be common ground, just the amp.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • JNinja
    JNinja Posts: 100
    So really, I guess I need a receiver suggestion first. I've been having a very hard time finding one thus far. I can't tell if one is common ground or not, and other than that I thought some here might have a good suggestion based on there own experience of a good 2-ch/5.1 receiver w/ pre-outs. Thanks
  • JNinja
    JNinja Posts: 100
    vmaxer wrote: »
    WoW, so I've been wasting my time with pointless searches lol
    Thank you for info! That I didn't know!
  • JNinja
    JNinja Posts: 100
    I honestly wish that my Technics receiver I picked up had pre-outs, as I like the layout very much. It seems like a good receiver, generally speaking.
  • Schurkey
    JNinja wrote: »
    http://www.audioreview.com/cat/amplification/a-v-receivers/technics/sa-dx940/prd_124278_2718crx.aspx
    Product Description
    Dolby Digital, DTS, and Pro Logic decoding 100 watts x 2 (stereo) into 8 ohms (40-20k Hz) at 0.8% THD — or 100 watts x 5 in home theater mode 5 soundfields (Hall, Club, Live, Theater, Simulated Surround)
    When you get your ears on a real preamp/amp, you'll kick that Technics to the curb and never look back. The thing isn't even rated to deliver the lowest octave (20hz--40hz).
  • JNinja
    JNinja Posts: 100
    Can I run an Ashly FET-500? Is it common ground? I found one for $200
  • JNinja
    JNinja Posts: 100
    Thank you all for help... after consideration, and conversations (offline) I went with a replacement for the Technics... ONKYO P-301 STEREO PRE AMPLIFER w/ Remote ...and an Ashly FET 500 Stereo Power Amplifier 800W... Appreciate all the help, and I'm sure I'll be back for help/mods
  • Nightfall
    Nightfall Posts: 10,083
    Is the picture how you are listening to them? Directly side-by-side like that?
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 52,360
    JNinja wrote: »
    This comment sums it up nicely, "I would expect the Ashley to be powerful and somewhat "rough" sounding—it was, after all, designed for sound reinforcement where power-to-weight ratio and reliability are more important than pristine fidelity."
    In addition, it has a loud fan and 1/4" or XLR connections instead of RCA's.
  • westmassguy
    westmassguy Posts: 6,850
    Welcome to CP, and the Rabbit Hole. Congrats on the 2Bs, great speakers. You'll not find much love for Pro Amps here. I've been chided for my Carvers, but they sound great to my ears. My PM-350 will drive my fully modded 2As to room shaking levels without breaking a sweat. Find what sounds good to you. You can always upgrade down the road as your budget allows.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
