2B TL Upgrade
deronb1
What is involved with the upgrade from going from already modded 2Bs to the TL? (other than installing 198s). Can I keep the same caps and resistors and just add another cap?
You have to add a 5.8uf Shunt Cap across the 2.7 ohm resistor, and change the female quick-connect/spade on the Tweeter wiring harness ground lead (white) to #.205 female quick-connect/spadeHome Theater/2 Channel:
dhsspeakerservice.com/ -
Thanks. That sounds like something I may be able to do!
WelcomeHome Theater/2 Channel:
