help
muslenutz
muslenutz Posts: 4
edited March 2004 in Troubleshooting
2 Questions
1. I have bi-amp or bi-wiring capability, but If I choose to keep it normal. Were do I hook up the main speakers, it says low or high frequency?
2. Also if I decide to biwire from my B channel on my amp, would my amp be good enough for me to hear a difference. I have a Yamaha RXV 596 100 for the front 3 and 70 a piece for the rears?
Post edited by muslenutz on
    F1nut Posts: 50,839
    edited March 2004
    1. Not knowing what speakers you have I'm still going to suggest you connect the cables to the bottom terminals and leave the jumpers in place.
    2. No.
    1 Suggestion
    1. Forget bi-wiring, get the best speakers cables you can afford and replace the stock jumpers with short lengths of the same cable.
  • muslenutz
    muslenutz Posts: 4
    edited March 2004
    They are rt16. It says High or Low, but the jumper is in place so I dont think it matters if it goes on one or the other. Mine has been on low for years.
  • danger boy
    danger boy Posts: 15,722
    edited March 2004
    with the jumpers in place. it does not matter if you use the upper or lower. no difference in sound quality at all until you remove the jumpers and go bi wire or bi amp. leave them in place and take F1nuts suggestion and get the best speaker cables/wires you can.
    PolkFest 2012, who's going>?
  • Frank Z
    Frank Z Posts: 5,860
    edited March 2004
    Most receivers will cut the rated output in half when both A & B speakers are selected. Probably not what you want.
