Polk LS90 Driver Buzz
GZaran
Hello,
Long time Polk user and brand new to the forum.
Purchased a pair of LS 90's off CL over the weekend- one of the drivers (third one up from the bottom) has a slight buzz that is audible at lower volumes. It stops if I gently push on it while still putting out sound.
Would this mean the driver is bad or possibly loose and would this be an easy fix?
Other than that the speakers are great.
Thanks for any help.
Best Answers
Hello,
Welcome to Polk's forum. You might want to try removing the driver, rotate it 180 degrees and re-install. If the audio angels are with you the change in position might pull the former with the coil away from the insides of the gap.
Regards, Ken -
If that doesn't take care of the noise, install another driver. I've had the same problem on my LS50's and a used driver replacement solved the problem.
Either order from Polk Audio, (tell them you're a Club Polk and get a discount) or buy used , they pop up every so often in the for sale area here or on fleabay.
Answers
Thanks for the replies- will try the rotation first and go from there. Will let you know.
