SDA 1 my left speaker goes on and off intermittenly
I have a left SDA 1 speaker that shuts itself off intermittenly. Sometimes there is a crackling sound. Most of the time it works. But I never know when it is going to stop working.
Something is going wrong with it. Can anyone tell me what is happening to my speaker?
  • PolkieMan
    PolkieMan Posts: 2,446
    edited April 2015
    Also remove the passive and check all the wires inside.
    If okay it might be time for a much needed crossover upgrade.
  • pglbook
    pglbook Posts: 2,265
    I had one of my SDA 2BTL speakers play at very low volume (compered to full sound on the other speaker) and crackle a little one day months ago. I removed all of the cables (IC, speaker wires) and checked and tightened all of the connections and, voila, problem solved. Give it a try. It is definitely worth a shot and hopefully will be an easy fix for you as well.
  • I have done that, I went so far as to replace the speaker wire.
    F1nut Posts: 52,103
    Bad solder joint on one or both of your binding posts.
  • nadams
    nadams Posts: 5,877
    Is it the whole speaker or just the tweeter?
    Ludicrous gibs!
  • DollarDave
    DollarDave Posts: 2,575
    Perhaps the poly switch is cutting in/out?
