SDA SRS Tweeters come on and off intermittently on Left speaker
Good day,
I have been a long time owner of polk audio. Started with my first Monitor 10b's and still Love the sound from them today.
I finally got me hands on some SDA SRS monsters and have played them for about 4 months now. I was testing some loud music for some friends and all of a sudden the tweeters were loud, then gone and when turning up the volume again the may or may not come back on. I have read that the polyswitch could be the issue and would like some guidance on what maybe the problem. As others had stated in their quest for answers, I did have them at some real earth pounding sound levels with my McIntosh C7205. I can find parts etc online, but would like some guidance on what parts maybe causing the issue and what methods I should utilize to pin point whether it is a speaker or supporting electronics. Seems many of the links in this forum do not work anymore, so reaching out.
Home Theater set up:
Projector - Epson 5030ub // Screen - ElunaVision 4k Reference 112"
Power - McIntosh MC7205 (5 channel amp) // TV - Pioneer Elite PRO-200
Preamp/processor - Marantz AV8003 // CD source - Pioneer DV-09
Main Speakers - Polk Audio SDA SRS
Center Speaker - Polk Audio CS350-LS
Surround Speakers - (2) Polk FX300i + (2) Polk monitor M3
  • tratliff
    tratliff Posts: 1,820
    When I had my SDA's I had the same problem in the begining. It was the polyswitch. If you contact polk they will send you replacements free of charge.
    I never replaced mine but found that if I controlled the volume they would not trip.
    It has been discussed that over time it gets easier and easier to trip them. In other words the more they are tripped the more they will trip.
    I have also read discussions on taking them out of the chain. But this comes at the cost of removing the protection and increasing the risk of damage. Once I found how all my equipment worked together they did not really bother me.
    Good luck and someone with much deeper knowledge of the protection circuit and x-over network will reply. These guys have a wealth of knowledge on this topic.
  • Nightfall
    Nightfall Posts: 10,083
    1) Call Polk CS and order new Polyswitches (safer albiet at reduced sound quality)
    2) Replace the Polyswitches with wire jumpers (will result in a slightly hotter top end)
    3) Replace the Polyswitches with 0.5 ohm resistors
    Really be careful with the volume knob if you choose option 2 or 3.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Dobolino
    Dobolino Posts: 13
    Nightfall,
    Thanks for the recommendations! I am assuming that the tweeters are okay, since they do come on intermittently or is there a simple test or method in ensuring there is no issue with the tweeters?
  • Dobolino
    Dobolino Posts: 13
    Also I have searched Youtube on how to take these apart safely, but could only find pictures and video's of the units already apart. I do not want to damage anything and be a Homer (do'h)..... ;-)
    Is there a link to pictured steps or video on dis-assembly out there you all know of?
    F1nut Posts: 52,142
    You overdrove the amp, sent a clipped signal and damaged the polyswitch, which was doing what it's designed to do. 100wpc is not enough to drive those speakers to earth pounding sound levels without bad juju happening.
    I do not believe Polk sells polywitches any longer, but you can purchase them online. You want an RDE090A and it would be best to replace the one in the right speaker as well.
    You remove the panel in the front, just the screws around the edge. You will need to desolder the driver connections to completely remove the panel with attached crossover.
  • Dobolino
    Dobolino Posts: 13
    F1nut, Thanks for your reply to my quest for information and hoping you nailed it so I can get them singing again. If I am going to pull the faceplate and input the polyswitches in "both" speakers, what would be recommended to do that makes sense. Don't need them to match to $50k power amp but would like them to run for many years to come.
  • Nightfall
    Epoxy all the magnets would be at the top of the "make sure they run for many years to come" list.
    afterburnt wrote: »
    F1nut Posts: 52,142
    I guarantee that I nailed it.
  • Dobolino
    Dobolino Posts: 13
    I guess my next purchase should be a dedicated amp for these big boys. Recommendations for the cost conscience audiophile.
  • Nightfall
    What is cost conscience to you could be different for someone else. How cost conscience?
    afterburnt wrote: »
  • Dobolino
    Dobolino Posts: 13
    edited March 2015
    I would say $1500 - $3500 for a two channel amp. I realize this price point leads me to the used, but well cared for market place.
  • Nightfall
    afterburnt wrote: »
    F1nut Posts: 52,142
    You can get a very nice amp for that money. Take a look on Audiogon, pick out a few that are in your price range, then post here, so we can give our 2 cents.
  • Dobolino
    Dobolino Posts: 13
    edited March 2015
    Here are a few I have found out there on the internet...
    McIntosh MC 2200 amplifiers x (2) = $2400 for the pair
    Bryston 3B SST2 Silver = $2400
    Parasound Model 2250 = $1400
    Bryston 8B ST 4 Channel Power Amplifier = $2000
    Oh and I live in a country where our money is close to the same value as Monopoly -- Canada, so I have to look in Canadian dollars as our exchange rate is UGLY!!!
    nooshinjohn Posts: 26,061
  • Dobolino
    Dobolino Posts: 13
    nooshinjohn, The Classe looks freaking NICE! Definitely something to investigate further!
  • Dobolino
    Dobolino Posts: 13
    My quest continues. :smile: On the forum it states to go with the RDO-194-1 replacement tweeter for my SDA's. I searched the Polk site; however it only generates new products when I search. Where would one go to purchase the RDO-194-1?
  • Nightfall
    Call.
    1-800-377-POLK (7655)
    afterburnt wrote: »
  • Dobolino
    Dobolino Posts: 13
    Thanks Nightfall! They didn't make it easy to find.
  • Dobolino
    Dobolino Posts: 13
    Well, I am going to start the somewhat long process of gutting my SDA's and begin the upgrades!
  • Nightfall
    Dobolino wrote: »
    What are your plans?
    afterburnt wrote: »
  • Dobolino
    Dobolino Posts: 13
    Found a fellow at dhsspeakerservice.com who has ID'd my Polks as the original Blade type and cannot be upgraded to a TL but he can perform upgrades just the same. I am going to get a few quotes from him on upgrades. So will be pulling the x-overs soon and then work towards getting the tweeters etc for the rebuild.
  • Nightfall
    He is a member here, his username is westmassguy
    afterburnt wrote: »
  • drumminman
    drumminman Posts: 3,396
    All reports are that his work is first rate.
  • Dobolino
    Dobolino Posts: 13
    Good to hear his work is first rate. I know I can solder, but not well enough to feel secure my beasts will get the best work. I will keep you posted on my experience; however it could take a while... :-) I would rather take my time have it all right than rush it. I will use my Polk 10b's in the mean time, so staying with Polk for sure!
  • dkfreebird
    dkfreebird Posts: 1,188
    David did my 2.3tl's and my dreadnought and his work is top notch.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
