Fuse Blowing Repeatedly
My DSW MicroPro 1000 is blowing fuses. When I replace the fuse and turn the subwoofer on the speaker oscillates like a heart beat, even if the speaker is disconnected from the receiver. I tried doing a "factory reset" but that didn't help. The speaker will pulse heavily 8 or 10 times and then blow the fuse. Voltage on back of speaker is set correctly. Any suggestions?
Best Answer
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Answer ✓
    Hello,
    Welcome to Polk's forum. There is a problem with the bass amplifier and it will have to be serviced or replaced. First thing on Monday call Polk's CS department at 1-800-377-7655 or send them an email to: polkcs@polkaudio.com and they will help you out.
    Regards, Ken
Answers
