Nice pair of Von Schweikert VR2s including original boxes and manual. and spikes
geppy1
Selling a really nice pair of Von Schweikert VR2s including original boxes and manual. and spikes These were purchased between 2006 and 2009 and are the beautiful African Hazelwood cabinets. They work perfectly and look very sharp. There are a couple of real slight dings and a couple of scratches . I tried to capture these in the pictures but overall they look stunning in a room and do not take up much space at all..
There are a number of very good reviews of this speakers online. One would be hard pressed to find a speaker of this size that goes down to 25HZ but these do. Very impressive bass with a very transparent soundstage The speaker can be tuned to the room using the rear firing tweeter which has its own level control . You can also add sand or lead shot to the buttom cavity to tune the bass. These have lead shot in them but it will be removed prior to shipping as it adds 30lbs to each speaker. A good all around speaker. Club polk Asking $695 or BO I am in MN As I have the boxes shipping is no problem Thanks
I HAV PICTURES PM ME
The rest of the specs:
System Type: 3-way, 4-driver system, with Transmission-line woofer design
Woofer System: Twin 165mm (6.5") composite cone drivers
Treble System: 1" (25mm) fabric dome tweeter with soft resin damping layers,
low distortion motor, Ferrofluid liquid cooling/damping, and long-throw voice
coil and motor assembly
Damping System: Resonance Trap cavity provided for insertion of lead shot.
Crossover: Global Axis Integration Network, 4th order slopes using cascaded
1st order filters at 200Hz and 2.2kHz. Polypropylene caps and air-core
inductors are utilized. All drivers are connected in phase.
Ambience Driver: 1" (25mm) soft dome tweeter with wave guide mounted at rear
of the cabinet and Dimension Control for effects level adjustment, calibrated
Frequency Response: 25Hz to 25kHz, -3dB (+/- 1dB in the midrange).
Sensitivity: 87.5dB/W/m anechoic, 90dB in room.
Impedance: 8 ohms nominal, 7 ohms low to 20 ohms high.
Power Handling: 20 watts minimum, 200 watts maximum r.m.s., 500 watts peak.
Wire Connection: Five-way binding posts, fitted for 6mm spade lugs, with CE
approved sheathing. Twin pairs are fitted, for bi-wiring or bi-amplifying.
Jumper straps are supplied.
Dimensions: 40 x 8 x 16 (HxWxD in inches)
Weight: 66 lbs raw, 85 lbs with sand, 95 lbs with lead shot
O-M-G!!! These are my FAVORITE speakers!!!
The African Hazelwood is absolutely gorgeous and they sound amazing!!! If I hadn't just purchased a whole set of new speakers, I'd be all over this. The rear firing speaker is a mid / tweeter called an ambiance driver IIRC and it works. These speakers dig surprising deep given their small footprint, due in large part to the transmission line bass enclosure. At this price, they are a flat out steal.
GLWS!HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
I have always loved this company, haven't heard too many of them but they sure are something I would love to own someday.
Great price, GLWTS -
Hi, what did you drive these with?
