sda 2b power handling question
sda2mike
hey! it's been eons since I posted here!
anyway, my sda 2btl's, with upgraded coils, sometimes at extreme volumes develop a crackle on one of the inside 6.5 drivers..im running an adcom gfa555..does this sound like I'm hitting the limit as far as current goes?
BTW when I do hear this crackle, my feet don't even touch the ground, I'm on that volume control so fast;)
thanks
mike
thanks
mike
Try switching driver with other speaker & see if it followsRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
I ran the same amp with my 2b's & it sounded wonderful. I never went that loud with them. It could be the driver is heating up or other issues need to be ruled outRandy-Maine
by David WMG
No. You've got a defective driver--or perhaps something internal to the speaker is rattling around (untethered wiring, for example). If this were an amp problem, it wouldn't be limited to a single driver.at extreme volumes develop a crackle on one of the inside 6.5 drivers.. ..does this sound like I'm hitting the limit as far as current goes?
If the issue follows that driver in another cabinet, time to get replacement.
Sounds like you have a driver that has a weak spider."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Sound like you have a driver that has a weak spider.
Or the VC former has come undone.
My RTA-11t driver was like that.
Spider was fine but the VC coil attachment was ripped in few places around.
Any luck pinpointing problem ?Randy-Maine
by David WMG
no..didn't get a chance..thanks for the responses:)
i'll have a look this week
