Which Sub?
I am getting a pair of Tsi400 and Tsi100 along with a Cs10, all in cherry, and I was thinking of getting the Psw110 or Psw125 to go with them for my home theater set up. Would either of those be a good choice or should I go with something different but it would have to be Cherry.
  • ken brydson
    ken brydson Posts: 9,100
    Welcome to CP. Subs don't have to match your speakers. It more boils down to budget, room size including openings to adjacent areas and listening habits. Budget is the biggest thing IMO. Get the biggest, baddest sub you can afford. Upgradis is a cruel beotch...
  • Inspector 24
    Inspector 24 Posts: 1,308
    Just get an HSU and call it a decade.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • seabeerob213
    seabeerob213 Posts: 1,843
    Look for used hsu, svs, or Velodyne, seem to be the best bang for your buck, new, try a bic F12 or Polk psw 505
    Before you go sub hunting though, I would get the cs20 center over the cs10. Better match with those towers.
    How big is this room anyway ? That's more a determining factor on the sub you'll need.
