Polk psw200
abeln
Hi does anybody know where I can find the circuit board for my psw200? I don't want to buy another sub if there is a chance I can buy the cb only.thank you guys
Best Answers
Well, that is a pretty old model. You will likely have better luck installing an aftermarket BASH amp or something similar that will fit from Parts Express or similar, or removing the amp altogether. plug up the hole with some MDF and speaker terminals, and run an external amp.
Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500 -
Not worth it in my opinion. You can buy those subs all day on the used market for under a hundred bucks. Heck, I've seen used 505's go for around 100.HT SYSTEM-
lsi 9's -
I've sold a couple for that much. Iirc best one was $80 locally.Up
Down
Answers
Try Calling Polk customer service yet?Up
Down
Hi Inspector 24...I called them[polk] a long time ago and they couldn't help me.I also e-mailed triad speakers which are the makers of the circuit board and they never answered me back.
I think triad is my best option and I'm going to send them another e-mail. -
Thank you guys for your answers.I think I will get another sub.
abeln. -
Not a bad plan. I had a PSW300 at one time, it was a very smooth sub...not really punchy or terribly musical, but filled int he lower regions good enough to compliment small speakers.
Then I upgraded.
A PSW650 will be closest to what you have now in character IMHO, PSW505's are punchy, but not especially deep or musical...kinda sluggish. Same for the 404, but not as much output or depth.
Honestly I'd look outside of the polk line, depending on your budget look at HSU Research.
Up
Down
