Interesting loudspeaker design
mhardy6647
mhardy6647 Posts: 35,562
edited January 2015 in Speakers
Saw this at AK and thought it was worth mentioning over here, too... interesting idea, actually... not necessarily just post-hipster ephemera.
http://danielballou.com/#cinder-speakers
  • Mystery
    Mystery Posts: 2,546
    What's holding the cinder block? :confused:
    nooshinjohn Posts: 26,181
    edited January 2015
    They also work as nice boat anchors, or to give Vito something to listen to while he swims with da fishes
  • westmassguy
    westmassguy Posts: 6,849
    LOL
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • westmassguy
    Mystery wrote: »
    Four threaded rods
  • drumminman
    drumminman Posts: 3,395
    Interesting idea, would like to hear those. Wonder how resistant to vibration cinder block is? Better than MDF?
  • westmassguy
    We're showing our age fellas. Unless you live near a coal power plant, the're all concrete block nowadays
  • WLDock
    WLDock Posts: 3,073
    Concrete Audio N1 - 27,034 Euros ($35,841). excl. Taxes and shipping
    TECHNICAL DATA MODEL N1.
    Housing: Concrete, monolithically poured
    System: 2-way closed-box, passive
    Frequency range: 34 Hz – 40,000 Hz
    Power handling: 100 W
    Sensitivity: 83 dB (1 W/1 m)
    Total Harmonic Distortion: < 1% bei 90 dB SPL (1 m) für f > 100 Hz
    Nominal impedance: 4 Ohm
    Crossover frequency: 6 dB/2,000 Hz
    Ports Single-wiring/bi-wiring
    Components: Scan-Speak, Kimber Kable, Mundorf, WBT
    Dimensions: Height: 110 cm (43,3 in)
    Width: 23 cm (9,1 in)
    Depth: 33 cm (13 in)
    Net weight: 80 kg (176 lbs)
    http://www.concrete-audio.com/en/concrete-audio/
    5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3
  • Mystery
    edited January 2015
    Mystery wrote: »
    Four threaded rods
    They don't seem to touch the blocks, just straight through the front and back boards.
    edited January 2015
    There are gaskets on the boards that (presumably) effect a seal.
    I think that a layer of some smooth mastic/plaster/polymer material applied to (e.g., trowled on to) the surfaces of the blocks that will touch the front & rear baffles would be a good idea.
    edited January 2015
    Not being an engineer I can't tell if that's crazy or good? What I do recall from a LOT of top end speaker designers is all the talk about good "resonances" and materials. Totem comes to mind. The Rainmakers are, correct me, if I am wrong, only 12 lbs in weight, have very little damping material and actually RELY on internal sound not being silenced?
    cnh
  • WLDock
    WLDock Posts: 3,073
    edited January 2015
    B&W states that their Matrix enclosures store less energy, and sounds better than concrete enclosures.
    I have an addled memory that regular old concrete is kind of ringy.
    I do know, e.g., that granite is a lousy material for, e.g., turntable "plinths" -- it is quite lively compared to, e.g., slate.
    One of the local NE gurus has embraced an interesting and ostensibly environmetnally responsible (and not terribly expensive) engineered material called paperstone for plinthing.
    http://www.paperstoneproducts.com/
    I don't know whether it has any potential for use in loudspeaker enclosures, though...
