Speaker Static
dirtydenim86
dirtydenim86 Posts: 95
edited January 2015 in Troubleshooting
Just went through the auto calibration saved the settings and now I'm noticing some static on all my speakers seems to be on multiple sources most notably on the surround sound speakers when there is no audio being sent to them. If I stick my ear next to the speakers and mute the source obviously the static noise is muted as well but that's how I can verify that there is some output static being sent to the speakers. I first noticed it when navigating through the menus of XBMC.
Had no issues at all prior to the calibration could it possible be the level calibration that was saved? Any help would be appreciated.
Onkyo TX-NR809
RTI10 Polk Audio Front Tower Speakers
RTI4 Polk Audio Bookself
CSi5 Center Channel RTI Series
PSW505 12" Subwoofer
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited January 2015
    Most auto eq's inside avr's create noise, and it is especially noticeable over HDMI sources sending PCM. It's normal. I bet if you turn off audyssey it will decrease.
    F1nut Posts: 51,719
    Is it static or a hiss?
  • Most auto eq's inside avr's create noise, and it is especially noticeable over HDMI sources sending PCM. It's normal. I bet if you turn off audyssey it will decrease.
    Turned off dynamic EQ after in the settings of my AVR and it's pretty much unnoticeable now.
    Onkyo TX-NR809
  • F1nut wrote: »
    More of a hissing sound.
    Onkyo TX-NR809
    tonyb Posts: 33,069
    edited January 2015
    Double check your connections. Make sure your using some quality cabling too. Some settings in the receiver will expand on any noise which xbmc is probably introducing. Could also be a compatibility issue with XBMC and the settings your trying to use. Try another input, like a cdp and see if the sound persist.
    If your not getting sound from the surrounds, most likely a setting issue. Make sure you read the manual too.
  • "Make sure you read the manual too."
    if you have to read the manual it is a design flaw. >:)
    tonyb Posts: 33,069
    LOL....I hear ya on that one, but....you'd be surprised pal.
  • I must have turned the dynamic eq option off at some point during my last setup ran audessey calibration again which enabled it.
    Onkyo TX-NR809
