just got a Yamaha RX-A1040 and Monitor 60 and 70
Is this enough AVR for these speakers?
  • afterburnt
    afterburnt Posts: 7,892
    it has pre out, I know nothing about preamps
  • deronb1
    deronb1 Posts: 5,021
    Probably fine, unless you play VERY loud. There are plenty of good 2 ch amps out there. Used in the 300-500 range and pushing 200 wpc if not more. Adcom, B&K, Parasound, Haffler, to name a few.
  • That's a very nice sounding Avr, but as mentioned, if you like to play loudly than you should add an ext. Amp, at least for the fronts.
  • afterburnt
    If I get separate amp for the fronts will that leave more power for the surrounds?
  • pearsall001
    pearsall001 Posts: 5,298
    Yes indeed. Also set your xo to 60/80 & small setting for the fronts. That will sweeten up your midrange & take a tremendous load off your Yammie.
    Here's a nice article that is worth a read...http://www.ecoustics.com/articles/set-speakers-small-receiver-setup/
  • afterburnt
    Thanks for all of the info so far. I guess this still leaves me with a few more questions.
    1. I would like more volume when necessary so I am worried about blowing out my speakers or AVR. Is there a minimum wattage output that I should be looking for, do I have to go 200+ or would something less give me more volume, less load and keep me from blowing stuff out?
    2. With a separate amp for the fronts will the enhancements etc. pass through from the AVR and into the amp unchanged?
    3. Will the volume controls have to be manipulated independently or can I dial it in on the amp and use the AVR volume to control everything without having to deal with the amp every again?
    4. Will adding a 2 channel amp to the pre outs leave the front speaker outputs on the AVR available for anything else?
    Thanks again for the help
  • afterburnt
    Emotiva XPA-200?
  • Erik Tracy
    Erik Tracy Posts: 4,673
    afterburnt wrote: »
    Power is your friend and having an amp rated higher than your speakers is ok/good thing.
    Your AVR will still function as the preamp and apply any/all equalization & effects to the external amp.
    The AVR will control the volume just as it did before for all speakers, including the external amp. Just be sure to re-run any YPAO auto-calibration on the Yamaha.
    Most AVR manuals will say NOT to use both the preouts and speaker outputs at the same time.
  • afterburnt
    Thanks Erik. I think I am going to get the 150 watt Emotiva XPA 200 $339 at Amazon. I haven't seen anything else in that price range and I have no idea how to go about buying used.
    tonyb Posts: 33,072
    afterburnt wrote: »
    Have you asked ??
    F1nut Posts: 51,799
    Inherently bright speakers with an inherently bright amp is not a good match.
  • afterburnt
    F1 nothing is permanent (especially these speakers). What do you suggest for three or four hundred dollars?
  • afterburnt
    tonyb wrote: »
    afterburnt wrote: »
    Have you asked ??
    Tony I wish I had more time to do the research. I hardly have the time or patients to dial all of my new stuff in let alone just listen.
  • afterburnt
    edited December 2014
    BTW I am trying to do a "jack of all trades" system mostly background music (classical) and some theater with all kinds of other junk in the mix. One of these days I will find all of my rock etc. CD's and try ripping them FLAC instead of mp3.
    tonyb Posts: 33,072
    afterburnt wrote: »
    Why would you rip to MP3 anyway ?
    A used Parasound or B&k amp is a better match for your speakers and can be had in the 4-600 buck range.
  • afterburnt
    I did not know any better
  • Erik Tracy
    It may seem intimidating at first, but you can find good deals used.
    Despite some drawbacks, audiogon.com is still a place to find used values.
    And don't forget the for sale section here - it may take some patience, but good deals show up here, too!
    tonyb Posts: 33,072
    afterburnt wrote: »
    No worries pal, that's why we are here to help you. We've all been in those shoes. Don't be afraid to ask questions no matter how dumb you may think it is. Good sound is about tailoring things to your own personal taste, and to get there requires some thought and gear matching with stuff that has been proven to work well together.
    Enjoy the forum.
  • NYmike
    NYmike Posts: 13
    I am confused about amps being referred to as bright. I have had many AVR'S in my day. Onkyo, Denon, Sony and a few yamaha's. My current set up in Yamaha rx A2010,
    RTI A5, CSI A4 FXI A4 Surronds, svs sb1000 sub, oppo bdp 103 for movies SACD AND FLAC files. this is the best system I have ever had, I had an Onkyo 1009 that sounded great for movies but really bad with music. The yamaha is warm sounding and much cleaner then the onkyo for music. For me brightness in music has a lot more to do with your listening environment furniture, carpet some room acoustics can change any speaker sound from one room to another. Just something to consider
    F1nut Posts: 51,799
    While the room certainly plays a role in the final sound, so does the gear. Some gear is inherently bright, which could also be called harsh, edgy, unpleasant, fatiguing, etc. regardless of the room.
  • NYmike
    NYmike Posts: 13
    agreed with some speakers mainly Klipsch, but to say yamaha and polk are a way to bright combination. I am just not hearing that with what I have. No fatiguing no harshness an certainly not unpleasant, my wife would have killed me if it sounded bad
    F1nut Posts: 51,799
    I was referring to an amplifier, not an AVR that the OP was considering.
  • afterburnt
    Well I hope I don't hate it. At any rate if I do $339 is one of the least expensive mistakes that I have made lol.
  • afterburnt
    I guess buying an mp3 download of a Pink Floyd album was a pretty cheap mistake. I just ordered the real CD from Amazon and now I will get the mp3 again that I already paid even more for but this time its free! %^(
  • Those monitors aren't bright speakers. I'd get the Emotiva with its five-year warranty. Should be an excellent match and won't come with the risk of buying used. But, it's your money.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • afterburnt
    I didn't think they were bright maybe more piquant but not bright lol. Amp is supposed to get here today I will hook it up after work and see. Thanks everyone for your input.
  • NYmike
    NYmike Posts: 13
    afterburnt wrote: »
    Go to emotva.com join the forum and get it for 279 or so
  • afterburnt
    Thanks Mike but what I see in the "e club" is XPA-200 was $399 now $339 thats what I paid at Amazon. I got it all hooked up last night I will put it through is paces today.
  • afterburnt
    I read somewhere that you should "never" go above 60 on the sub xo. I wish I could find the article where I saw that. Can anyone elaborate on this?
