SDA interconnect
I am looking for ideas / suggestions for a DIY interconnect for my SDA 1c's. I am currently using a piece of 12 gauge speaker wire ( one lead of the two ) terminated with banana plugs. The 1c's have Cardas binding posts for the ic connection. Thoughts and suggestions??
  • voltz
    voltz Posts: 5,384
    Me too for the CRS+. I am leaning towards Analysis Plus oval 12's or chocolate ovals, and matching speaker cables....Thoughts and suggestions for me too
  • Faustin
    Faustin Posts: 1,151
    I picked up some bulk Alpha Core Goertz MI-1 on sale from Soniccraft and put together cables for one of my 2 channel rigs with my RTA 12c's. Only listened to them for about 2 hours but my initial thoughts are that I am pleased with them. Have to do some more listening but for $3.25 / foot I figured I could not go wrong. I am thinking about using that for an interconnect and for my SDA's.
    F1nut Posts: 51,930
    You should have used both runs of the 12 gauge, but to answer your question I believe it is best to use the same cable for the SDA cable as your speaker cables. Only makes sense, eh?
  • westmassguy
    westmassguy Posts: 6,850
    Faustin wrote: »
    Bruce, recycle the Cardas for another project, and put SpeakOns in. Use any wire you want, and like Jesse said, same wire for the speakers and Interconnect.
    Same goes for you Darryl
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Faustin
    Thanks gents. Me wife wanted to know what what I wanted for Christmas, sooooo I have 40 feet of the Goertz cable coming. I was wondering about using both runs for the ic and yes I will do that. Of course the speaker wires to the amp will be the same. THERE IS A SANTA CLAUSE :D
  • voltz
    voltz Posts: 5,384
    Sounds great! I will use the same for both.
