Receiver for SDA1
What are you driving your SDA1's with? I have a Harmon Kardon Citation receiver that I will hook up to mine when I am done with a few simple mods.
  • bluecomet
    bluecomet Posts: 1,118
    I would always drive my SDA's with a dedicated amp. If you have pre outs on your receiver you can use it as a pre amp. The SDA's will really open up if they have the right kind of power.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • Faustin
    Faustin Posts: 1,151
    Would not recommend running your SDA's with a receiver. Not sure what your HK is rated at but you want 150 - 200 rms for SS and can go less with tubes. I have 1c's that I run off of an Adcom GFA 555 at 200 rms at 8 ohms and around 350 at 4 ohms.
  • GDP
    GDP Posts: 27
    I can drive my srs 2 s with my Kenwood kr 9400. Its not like there on a dedicated amp but it don't sound bad, or get hot.
    F1nut Posts: 52,000
    Flathead38 wrote: »
    Those speakers present a 4 ohm load, so you better be sure your receiver can handle that.
  • Schurkey
    Schurkey Posts: 2,122
    edited December 2014
    Flathead38 wrote: »
    First Guess: The HK Citation will be fine. Yes, it needs to be able to drive a four-ohm load, and it must be common-ground. I suspect but have not confirmed that your Citation is both.
    I used a receiver with my 1Bs for years. Seemed to work fine at the time; although I now suspect that the receiver was not truly common-ground; perhaps having a few ohms of resistance between the channels.
  • The Citation will run multiple sets of speakers at either 8 or 16 ohms at 85 watts RMS and a single pair of speakers at 4 ohms, but it does not indicate the wattage. It is also a common ground receiver.
  • westmassguy
    westmassguy Posts: 6,850
    http://www.thevintageknob.org/harman_kardon-Citation_Receiver.html
    Hit the "Specs" button
    135 @ 4ohms
    It has dual transformers, so I would double check the common ground issue.
    It should power them at low to moderate listening levels, but I would not push it. The SDA-1s are 4 ohm, but drop well below that at certain frequencies.
    That's why most of us use a separate Power Amp, that can handle <4 ohms loads.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
