PSW505 output/sound stopped/almost none
PSW505 was working perfectly, Set volume on unit to about 40-42 percent with LFE IN. Stopped using entertainment system for a couple of months and now without any changes/modifications there is no sound/rumble from PSW505. What are the possible problems and the procedure to test? Thanks.
Answers
  • [Deleted User]
    Hello,
    Welcome to Polk's forum. One of the way to test your woofer is to turn it's volume all the way down and remove the sub-cable going into the LFE input. Then connect either the right or left audio output of your DVD/CD player into the LFE input. Then begin playing a CD and slowly turn the volume up on the sub. If there's no output give Polk's CS department a call at 1-800-377-7655 or send them an email to: polkcs@polkaudio.com
    Regards, Ken
