Wiring question SRS 2.3 (Non-TL)
I have a potential customer with a set of SRS 2.3s. He has the original Doughnut Drivers, MW6513, which are 4 ohm. The other two drivers are MW6510s which are 8 ohms. He has tested all the drivers out of the cabinet, and they all function. Once installed, the doughnuts don't produce any sound. I sent him the Schematics, and the left and right wiring diagrams. According to him, they're wired according to the diagrams. I'm a bit baffled. The Dimensional circuit is supposed to be 4 ohm total. Not sure how you can do that with two 4 ohm and two 8 ohm drivers. Seems to me, they should all be 4 ohm drivers in a series/parallel configuration.
Any advice would be appreciated.
Home Theater/2 Channel:
dhsspeakerservice.com/
