Dedicated AC Power Line For System
If anyone here has done this, what are the do's and don'ts as far as having one installed? Is there a Good-Better-Best way to get it done?? I thought I'd ask here as I am thinking seriously of having this done and know nothing about it. Any help would be appreciated as far as to what to be asking for and I'm sure it wont be cheap, nor am I looking for a cheap route. Quality is important to me. Thanks in advance,
THJ
Best Answers
    EndersShadow Posts: 17,723
    edited October 2014 Answer ✓
    If I had to make a suggestion it would be this. Have them run one powerline to a subpanel located near where your stereo gear is. Then from that subpanel you can start with using just ONE dedicated line, but get one with at least 4 connections so you can have up to 4 dedicated lines in the future. Much easier to run one cable close to the end termination, and then 4 small runs to your lines than to run 4 long lines straight from the panel.
    In addition make sure you get a nice receptacle as well. PS Audio PowerPort's seem to be a good call. And then of course get some Pangea powercables once you've got your dedicated power lines.
    My thoughts.....
    Its on my list to do (just like I suggested) but given my layout is gonna be too costly unless I can convince @ZLTFUL‌ to pay me a visit and help me out on the downlow....
  • BlueFox
    BlueFox Posts: 15,250
    Answer ✓
    I have 4 dedicated 20 amp lines. Three for the two channel system, and one for the HT. Plenty of people have done this, and is one of the more inexpensive tweaks you can do.
    SCompRacer Posts: 9,128
    I've run two 20 amp circuits for my two channel. One for my amp, the other for the gear. One thing to remember, you don't get the full 20 amps. National Electrical Code specifies that a circuit should not pull more that 80% of the rated load of the circuit. Most breakers will trip 2-4 amps below rating with constant load. Good rule, always do the math and total up the loads for your circuit(s) before going ahead. With audio, sometimes it's good to have some head room if you want to add a bigger amp down the road.
    You going to have someone do this for you? They should be qualified, licensed and bonded is good. Check local code. Do you have to run pipe (conduit) from breaker box to outlet box, or just for exposed wiring? (Some folks pull romex in conduit, conduit extends into wall, romex continues to box). I like pipe all the way so I can pull additional wire if desired.
    Do you have a basement? Easier to get into walls from below. How long of a run? 12 gauge will work for 20 amp circuit unless it's a really long run. There are calculators for voltage drop/amperage that help select proper gauge for a run. I have short runs so I just used 12 gauge.
    A qualified guy will know local code and box/pipe fill specs. By fill I mean just cause you can get it all to fit don't mean it's up to code. ;)
  • GlennDog
    GlennDog Posts: 3,158
    Answer ✓
    SCompRacer wrote: »
    ^^^I like 99% of the comment from Rich^^^
    Good advice. But the part about pulling Romex thru conduit is a no-no, at least in my area. Too much heat build-up. If I'm not mistaken THHN is the wire to use.
    Just my .02
    G
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    GlennDog wrote: »
    SCompRacer wrote: »
    Just my .02
    G
    IIRC Chapter 9 in the NEC book has all the conduit fill info and even tells you how to calculate the area of an eliptical cable (Romex for instance). Romex in pipe is legal in the city next to me, usually used for short runs from main box into a wall (no exposed wiring allowed, but romex in walls/ceiling OK). Or romex from covered drop ceiling runs through pipe to exposed outlet box on concrete wall, etc. Next town over spring clips holding ground wires to box is OK. I like ground wires screwed to metal box.
    Thats why I always suggest check local code.
Answers
  • tophatjohnny
    tophatjohnny Posts: 4,189
    I'm checking into it tomorrow! Thanks
  • kevhed72
    kevhed72 Posts: 5,169
    I just received a quote for a 125 amp sub panel, 6 breakers and 2 whole house surge protectors (1 for each panel) for 850.00. This sounds reasonable since the sub panel installation scares the shite out of me.
    F1nut Posts: 52,018
    You'll be going with Coconut wire then I take it.
    F1nut Posts: 52,018
    Interesting....one would think the aluminum would act as a heatsink if anything. So out of curiosity, I just grabbed one of the flexible conduits filled with 10 gauge Romex, cool as a cucumber. Maybe I need to crank up the volume. B)
  • westmassguy
    westmassguy Posts: 6,850
    One or two, 20 amp dedicated lines, using BX, not Romex, would probably be the easiest. BX is Shielded/Armored cable, and less likely to pickup interference from adjacent circuits. As mentioned, Pipe/Conduit, with THHN wire will also work, but will me more expensive than BX cabling.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • tophatjohnny
    Close Jesse, but there's a sale on "CocoF1nut" wire and is said to provide ultra bottom end support as well as scriptofliptic resonance to the flackadunka wave particles, so probably hooking up with that. Plus there's a 7 year same as cash deal offered. Can't go wrong there. Am I right??
  • kevhed72
    Not a bad idea at all...thanks
