Where to buy XLR pins to stop hum with RCA
polkfarmboy
I need about 5 of these for a krell, its those little double pin things that stop the hum when using RCA. Does any one know where to buy them or even what the proper name of these are?
RCA and XLR are two different animals. RCA is a Consumer grade, unbalanced connector. It has two conductors, a center "hot" lead, and an outer shield, which is negative or ground. XLR is a Pro Grade, Balanced connector, with 3 to 7 pins, one is normally ground, and makes contact first.
If you're looking for an RCA to XLR Adapter, Parts Express carries many types.Home Theater/2 Channel:
dhsspeakerservice.com/ -
He is looking for the U shaped pins for the XLR input, they are used when using RCA cables..
CGSP from Cardas..
Ah, my mistakeHome Theater/2 Channel:
Thanks TF!!, really appreciate the help bro.
