Pioneer Elite sc-63 Issue
About once a week I'll go to turn the volume up or down on the remote and nothing happens. Its like the remote is dead.... but its not. If i hit power on the remote it says zone 2 on.
So i spend 1/2 hour **** around with settings/removing batteries then all the sudden everything is back to normal again.
ITS FREAKING ANNOYING and I can't figure out what keeps putting it into this "mode".
The manual doesn't explain why this keeps on happening so I thought I would ask here and see what you all think. Am i pushing a button on the remote on accident that keeps sending it into this zone garbage. I don't use extra zones or anything, its just standard surround sound.
Am I the only one who has this problem?
  • kevhed72
    kevhed72 Posts: 5,146
    I think I have done the same thing several times....it is annoying, but I cannot recall how to remedy it.
  • I messed with it for a few, couldn't get it to work right, then all the sudden everything was fine again. I just wish i knew what caused it, thanks for posting :)
  • PSOVLSK
    PSOVLSK Posts: 5,382
    I bet you answered your own question. Bottom row of buttons performs operations for Zone 2 and 3 when pushed.
  • mantis
    mantis Posts: 17,408
    edited October 2014
    It doesn't go into any mode by itself , someone is hitting the zone 2 button my man.
    Do yourself a huge favor , put that remote in a drawer and get a Universal remote. This way you can't press zone 2 when your trying to use the Main zone.
    Dan
  • deronb1
    deronb1 Posts: 5,021
    I know my pio remote had a slide at bottom for zones. Would be hard to do by accident. If something was not working, i always hit the receiver button and then things were controllable again
