PSW404 Sound In and Out
I have noticed over the last year that my PSW404 stops working from time to time. Usually, I can flip the power switch and it comes back on. The same procedure now only works for a few seconds, if at all.
Power light is always on, even when no sound. Input was isolated and working properly. Any thoughts?
Receiver: Pioneer Elite SC-05
Front L/R: Polk Rti10
Center: Polk Csi5
Rear surround's: Polk Fxi3
Sub: Polk PSW404
TV: Samsung LN46A650 46" LCD
PS3
  • Hello,
    It is possible the "auto on/off" is not working properly. Check with Polk's CS department to see if they are offering service on that model.
    Their number is 1-800-377-7655.
    Regards, Ken
  • Thanks Kenneth. I will give them a call.
    Interestingly, I played around a little more with it this weekend. What I found is that when turned off, then back on. Exactly 5 seconds later it will turn on for 1-2 seconds. I doesn't matter if I use the switch (both "auto on" and "on") or unplug it. Either way, count to five... on, then back off.
    Center: Polk Csi5
    Sub: Polk PSW404
    PS3
  • to see if they are offering service on that model.
    Spoke with CS today and unfortunately the answer is no, as many parts are now unavailable.
    He was very intrigued by the symptoms noted above, but through discussion we were unable to isolate any likely causes. Only option would be replacement of the amp, but the cost of the part far exceeds value given prices of new subs or maybe a nice craigslist score.
    Center: Polk Csi5
    Sub: Polk PSW404
    PS3
