Nanner plugs...
Get ready to hover over your "LOL" buttons...
In my short foray into mid-fi audio, I have either purchased pre-terminated cables or used bare wire.
The HT that I have spent lots of time working on was still using bare wire. I have been switching amps in and out which has been VERY annoying with bare wire. Plus recently, I purchased a 3 channel amp and my 12g wire wouldn't fit very well so it was kinda sketchy.
Long story short, I installed 7 pairs of bannana plugs today in my HT.
It was actually simple, fun, and very rewarding.
Well worth the effort.
Carry on...
  • Which ones did you use? I've used a bunch and found that the Monster quick connects are actually some of my favorite. The GLS Audio locking banana's were my least favorite.
    Audioquest makes some good ones, but man are they pricey!
  • hochpt21
    hochpt21 Posts: 5,423
    Just some cheap ones from Cable Matters. Closed screw bananas for about 2 bucks a pair.
  • I love the audioquest's but these are more practical
    http://www.amazon.com/AmazonBasics-Gold-Connector-Banana-Plugs/dp/B0090CVJZ4
    Garage | Polk Monitor 5B's
  • I use the Nakamichi Plugs. I buy them in quantity. Solid Copper with Gold Plating. http://www.ebay.com/itm/181503539801?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • hochpt21
    It was fun to do, and kind of addicting. It had me googling some stuff on how to make my own cables. That might be fun to do down the line.
    EndersShadow Posts: 17,690
    edited September 2014
    If your going to do that, honestly buy the parts from Doug and DIY it yourself.
    I've talked to him on a couple occasions and hes more than willing to walk you through step by step how to build them.
    That said the most expensive part is the connectors he uses, which are good connectors, just be aware that those are the pricey part, but worth the money as the terminations matter just as much as the cable in between.
  • voltz
    voltz Posts: 5,384
    I agree with Dan about going thru Doug, as I showed a friend the cables Doug made me he wanted some but didnt want to play that much for them so I bought what he need from doug to make his own, here are 2 pics - pic 2 is the one Dougvem0lit9xvne.jpg
    made and the other (pic 1) we made for him
    ^ This
    I love mine. I use them on every speaker I have. easy to install hold very well. They have a reset-able break away point which saves speaker and amp terminals from being broken if something falls or hits them. I am gald they had that on more than one occasion.
    Plus they look fantastic hooked up
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • xjghost
    xjghost Posts: 1,115
    Am I reading that right? 30 plugs?
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • westmassguy
    westmassguy Posts: 6,850
    xjghost wrote: »
    That's correct. Insanely inexpensive, but great quality.
