RTA15TL resistance readings
myron horn
Getting set to have a new set of crossovers built for my newly acquired RTA's....BUT....before I start, I want to make sure the drivers are up to snuff...when checking them with a multi-meter....what should I have as an acceptable reading when checking the resistance? Thanks in advance for the help!
Best Answers
Is this thread helpful?
http://forum.polkaudio.com/discussion/118471/current-production-drivers-vintage-support#latestJay
Found it at the top of the Vintage Speakers subforum. Make sure you go back there to find the crossover schematics "sticky" at the top of that subforum as you plan your crossover work.Jay
Answers
If you think the speakers are working correctly, you can test the drivers against themselves--The midwoofers (are they all MW6510 on 15TL?) should have essentially the same reading on a multimeter, etc.Jay
Thanks agfrost! That's EXACTLY what I was looking for! And to answer your question, I believe they are the mw6503 on the 15tl's....Tahnks for the help!
