Just a hint of harshness
My modded CRS+ speakers and system in general has gone through a ton of change in the past month. Here is what I've changed:
-Big new Tube Amp (yay) 90wpc, Rogue Stereo 99 Super Magnum (beast)
-New cables from Doug. This was the first time I spent almost $300 on cables (thanks Club Polk)
-New caps and resistors (sonicap & mills) for the cover
-New Jantzen inductors on the xover's
-New Erse Super Q 16mh inductors (if you haven't done this yet, you're a fool. What a difference in bass response)
-Dynamat Xtreme for the speaker baskets
-New Oppo 105D
Obviously this is a ton of change in a couple of months time and I understand things are still burning in.
What I'm hearing is some harshness around around the upper mid treble range. The "high highs" don't sound harsh if that makes sense. I'm sure I'm going to hear that burn in is the cause but I have a feeling it could be something else. Maybe an error in the xover? I have swapped out amps & preamps and the problem is still there. The tube equipment helps but it doesn't solve it. I can't say whether or not this was an issue before the mods or if I'm just listening more closely. I do have a .5 ohm resistor in place of polyswitch btw.
Just looking for ideas at this point & thanks guys!
