CS1 Center Dome Tweeter (RD1585-1)
Encrypted_God
Encrypted_God Posts: 10
edited August 2014 in Vintage Speakers
I (finally) blew it out so I need a replacement. I guess I pushed it too hard. Anyways..Doin' a extensive search I am unable to find one. So...do you have a suggestion? other than buying a new center.
If there's a compatible dome I can get, that would be fine too
Pioneer™: VSX-519v
PolkAudio™: Monitor60 Series-II
PolkAudio™: PSW10 Sub
PolkAudio™: RM7 Satellites
PolkAudio™ CS1 Center
Post edited by Encrypted_God on
    F1nut Posts: 51,944
    edited August 2014
    Have you called Polk?
  • Encrypted_God
    edited August 2014
    No sir
    <edit>
    Come to think of it, would this fall under warrentee
    Pioneer™: VSX-519v
  • westmassguy
    westmassguy Posts: 6,850
    edited August 2014
    Call Polk Customer Service, and have the Serial # handy. They'll tell you if it's under warranty or not. Mention you're a Club Polk Member, if you have to pay for it. You usually get a discount.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Encrypted_God
    edited August 2014
    Thank you. I'll call them. I know I registered them about 3-4 yrs ago when I first got them. I'll check. Nonetheless...thanks again
    Pioneer™: VSX-519v
    F1nut Posts: 51,944
    edited August 2014
    That's not covered under warranty.
  • Encrypted_God
    edited August 2014
    "guess" is the keyword.
    Pioneer™: VSX-519v
  • hochpt21
    hochpt21 Posts: 5,423
    edited August 2014
    Where are you located? I have a CS1 to unload fairly cheap. Shipping may be the killer though.
    F1nut Posts: 51,944
    edited August 2014
    Don't kid yourself or us.
  • ken brydson
    ken brydson Posts: 9,016
    edited August 2014
    Polk CS may surprise you. Give 'em a call. I wouldn't be shocked if they sent you a warranty replacement. If they do, just watch your volume knob. Your AVR is pretty entry level. Pretty easy to clip...
  • Encrypted_God
    edited August 2014
    hochpt21 wrote: »
    Calm down kiddo. It will be OK.
    Yea...things worked out just fine. I contacted PA and they were/are more than willing to accommodate. I don't or can't push it all that hard as I live in a APT complex. But for the last 3 1/2 years since I've had them, I am completely satisfied.
    And yes itnl.gif...the AVR is entry level without a doubt, but as I said; (for my usage) I am completely satisfied.
    on a side note; I spend all my money on my gaming rig. nv5o.gif Maybe I should stop neglecting my other toys.
    Pioneer™: VSX-519v
    F1nut Posts: 51,944
    edited August 2014
    You're right and welcome to my BOZO list.
  • Nightfall
    Nightfall Posts: 10,083
    edited August 2014
    Thanks everyone for your replies, I do appreciate it
    You're welcome, squirt.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Encrypted_God
    edited August 2014
    LOL...NICE! Being called squirt AND being carded when buying a 6 pack is the best compliment ever. I mean being 48? every little thing helps
    Pioneer™: VSX-519v
