Need Driver numbers for RT-55 Bookshelf Speakers
Whiplash1
Whiplash1 Posts: 3
edited August 2014 in Troubleshooting
Hi, Posted this before don't think I was understood. I need the driver model numbers for these speakers. I know I can find them if I take them apart but they are ok and I need this for future info so I can p/u a set if I find them at a decent price. And if anyone knows where would be a good place to get them from? Thanks
Post edited by Whiplash1 on
    F1nut Posts: 52,150
    edited August 2014
    I understood you perfectly.
  • dbKiller
    dbKiller Posts: 316
    edited August 2014
    They are very easy to pull out to find the part numbers, I replaced the tweeters in a set of mine, lay one on its back, pull the Allen screws, gently pull the trim ring ( the tweeter will come out with) unplug the tweeter to fully remove the trim plate. Then the drivers just lift out, no screws holding them in.
    Home Theater: LG 60PB450; Pioneer Elite SC55; RT2000P; RT55P; CS400p; FX500; SVS PB12-Plus/2; PS3 360GB
    Office: Onkyo TX-NR616; RT2000i; RT800i; CS400i; DSW Micropro 4000; XBOX 360 250GB; LG BR370; Panasonic Plasma
    Bedroom: Sony STR-DH820; CS400p; RT55p; Sony Grand Wega 55"
    Retired: Sony STR-DN840; Yamaha HTR-6130; Sony STR-DN520; Paradigm Phantom V.3; Paradigm CS-270V.3, Cinema ADP V.3, PS1000 V.4; Polk S6; Onkyo TX-NR809; Monitor 50, CS1; FXi3; PSW350
  • dbKiller
    dbKiller Posts: 316
    edited August 2014
    Easiest way I found to find replacements, keep an eye on Craigslist, I have located a few sets of RT(P) stuff here and there, swapped drivers and or tweeters, then resale for most if not all of my money back. Only drawback is you have to be patient for some deals. Good luck.
  • dbKiller
    dbKiller Posts: 316
    edited August 2014
    And it just struck me, you didn't specify if you have an I or p model. Blue drivers from the I models are different from the black drivers from the p models. All I sent earlier applies to all.
  • Tbone289
    Tbone289 Posts: 661
    edited August 2014
    RT55 tri-laminate tweeter: SL6502
    RT55 mid-bass driver: MW7017
    RT55i mid-bass driver: MW7203
    I'm not 100% sure, but I believe they both used the same tweeter... Honestly, I would still pull one of the good drivers out to be 100% sure on them also.
    Ebay is about the only place I've had any luck finding any of these discontinued drivers.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
