Cabinet Design or Specifications for SDA SRS 1.2tl
MarkMcC
I own (or owned) a pair of SDA SRS 1.2tl but my house was flooded and the speaker boxes got wet and failed. I saved the speaker drivers and hardware. I am now looking to rebuild the 1.2tl boxes and am looking for the Cabinet Design and Specification Diagrams. Does anyone know where I can go to find this info. Thanks.
Post edited by MarkMcC on
I can give you the external measurements, 63 1/2"H x 21 3/4"W x 13 1/8" D.Political Correctness'.........defined
President of Club Polk -
If for some reason to decide to not pursue this task you are looking at, would you please think about selling me the crossovers?
And I know somebody who would love to have the passives... Not that I'm a vulture or anything. It will take a lot of MDF, and I hope you're really good friends with a router, because you'll be at that a while. Good luck!SDA SRS, SDA SRS1.2TL, SDA-1C,SDA 2B, Soundcraftsmen Amplification (A5002s, MA5002s, MA5002As)
Actually sounds like an awesome long term project. Newer materials, better internal bracing etc.Home Theater/2 Channel:
dhsspeakerservice.com/ -
To the OP, you should contact Nooshinjohn as he has talked about building better cabinets for his 1.2tl's. May be able to exchange ideas."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
MarkMcC, In all seriousness, if you need internal dimensions, spacing on drivers, or anything along those lines, let me know.SDA SRS, SDA SRS1.2TL, SDA-1C,SDA 2B, Soundcraftsmen Amplification (A5002s, MA5002s, MA5002As)
