To the garage...Carver done blowed up!
I-SIG
I-SIG Posts: 2,243
edited February 2004 in Troubleshooting
Well, I guess third time is a charm. The M1.0 I've had for several years now gave up the ghost, I think. No more Carver for me!
After thouroughly determining that the TFM-42 I just bought has a dead left (GRRRRRRRR), I decided to hook my M1.0 back up. When I flipped the power switch, I got an audible buzz in the left channel. No biggie, I thought, as the M1.0's can be a little noisy during power-up and shut down. Then, a few seconds later (like 5 sec) I got the feedback from hell from both channels and the LED's on the front pegged to green (no headroom). I quickly flipped the amp off.
Here's my question: Is it possible I damaged my RT55i's during this episode?
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
  • HBombToo
    HBombToo Posts: 5,256
    i hope not but at least ya have Polk CC:D
    ***WAREMTAE***
  • Wardsweb
    Wardsweb Posts: 939
    Did you have the TFM-42 hooked to the speakers before your m1.0 episode? Your feedback was more likely DC voltage dumped into your speakers. The most common effect of output transisitors shorting. Take the grills off your speakers and with your finges on either side of the cone dust cover push the cone in and out slowly. It should move free and easy. Make sure to keep equal pressure on the cone when doing this, as the clearance tolerances are very small. If you feel a rubbing, you have overheated the voicecoils. Not likely as they only saw the current for a short period of time, but possible. Another possibility would be an open voice coil, meaning no sound when hooked up.
  • I-SIG
    I-SIG Posts: 2,243
    Yeah, I did. I was tryin gto be super sure that the TFM-42 was dead on the left and swapped to speaks to eliminate a variable. At least I didn't do this to the SDA's!
    I'll check the freedom of movement of the cones this evening. Thanks.
    Have a receomendation for a new(er) amp? I made a list in the electronics section but will take suggestions anywhere.
    Wes
  • Tour2ma
    Tour2ma Posts: 10,177
    Is it possible the switch to bridge the 1.0 to mono was (is) engaged?
    More later,
    Tour...
    Vox Copuli
  • I-SIG
    I-SIG Posts: 2,243
    Nah. It takes some effort to swap, like removing two screws.
    Wes
  • hoosier21
    hoosier21 Posts: 4,413
    The real question here is how many beers were involved??
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • I-SIG
    I-SIG Posts: 2,243
    LOL!
    None. I'm not sure if that's a good thing or a bad thing! :mad:
    Wes
