Placement of eight drivers in my SDA SRS 1.2 help please
Dabutcher
Dabutcher Posts: 2,606
edited July 2014 in Vintage Speakers
I was reading some other threads here earlier and was checking out the SDA handbook links . I never realized mine had four MW6503 and four MW6511. In each speaker. When I took them apart a year ago to do the JB weld and Dynamatting and Larry's rings I wrote down where each speaker was in the cabinet to put them back the same way. I do not remember noticing two different part numbers on them? I pulled top left and bottom left on right speaker tonight and both are MW6503. Can someone tell me placement order for all eight drivers in the right and left speakers? My model is the 1.2 transition model with thirteen crossover cover bolts. As always thanks for any help. Peace. D
Post edited by Dabutcher on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited July 2014
    So Sal says that the outside speaker is the stereo row 6503 and the inside row is the dimensional 6511 row. I don't recall ever thinking that specific tidbit through.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited July 2014
    6503's are the stereo drivers and are on the inside, 6511's are the dimensional and are on the outside.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • westmassguy
    westmassguy Posts: 6,850
    edited July 2014
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Dennis Gardner
    edited July 2014
    Read the diagram carefully, since Sal's posts and my interpretations of his video post while he was posting text are clearly at odds with the diagram and thus wrong. I always thought Dims are to the outside.
    Thanks again, Dave. Lots of info gets thrown around here misunderstood and misstated.
    This thread is a perfect example of how our favorite speaker line with some of the most sophisticated crossover networks ever put in a cabinet, can so easily get screwed up over the years of multiple ownership and tinkering and not be performing to spec. Lots to go wrong with 12 drivers in a cab and multiple sets of signals firing at different levels of power and intensities. At times I wonder if a numbering system and hard wiring might have eliminated some of this issue (ala Bose 901). Then again, they never intended them to be user serviceable pieces.......
  • headrott
    headrott Posts: 5,496
    edited July 2014
    The MW6511's should be on the far left (outside) of the left speaker, and the far right (outside) on the right speaker. This is by design, and the schematic shows this ito be true. Alternatively, the MW6503's are on the left side (inside) on the right speaker, and on the right side (inside) on the left speaker. The 3.1TL's are the same way (with fewer drivers of course).
  • Dabutcher
    edited July 2014
    Thank you. I will check everything out tonight. Peace. D
  • westmassguy
    edited July 2014
    Dennis, the early 901s, Series I & II used 8 ohm drivers in a rather complex Series/Parallel configuration. The later Series III through VI are a simple Series configuration.
    F1nut Posts: 51,939
    edited July 2014
    Lasareath wrote: »
    so the 6511's should be on the inside and the 6503's on the outside
    Sal, that is wrong. It should be the other way around.
