Most bizarre problem I have had
NeilGabriel
I have an older Panasonic Viera 720p TV. I run a Roku box into it. This problem occurred with a the 2nd gen and now the 3rd gen box.
In the middle of watching/streaming a show, there is a pop and the TV shuts down. When I turn it on, I get a red blinking power light. I have researched and read up on the "blinking light issue." May be linked to a power board (thingy).
However, if I unplug the TV and plug back in, it works again. This happened a couple times in the past.
Today, it happened again.....except after restarting the TV and the program, when I got back to the same point in the show/stream, it did it all over again. I was on Huluplus. So, I switched over to watch the same program on Amazon. When it got to the same point in the same show, it shut down again. I never tried this in the past.
I could see how some bad data stream thingy could cause the TV to shut down, but from two different providers?
Ideas?
Ideas?
Post edited by NeilGabriel on
Yup that's would be a good place to start
