Need patient guidance regarding woofer replacement
Pastor Bill
May have located a source willing to part out his Fried Model Qs. How complicated is replacing a woofer in a 2 way? I'm assuming it involves removing the cosmetic ring, unscrewing the speaker and de-soldering two leads? Then of course, reversing the steps to install. Anything else of which I need to be aware?
Jesus said "I am the Way, the Truth and the Life. No man comes to the Father but through Me." - John 14:6
NAD 7140, Fried Model Qs, Pioneer PD-4700
Post edited by Pastor Bill on
Most speakers use quick connectors which negates the solder/desoldering.
but you laid out the steps to most all much older speakers. -
I would also check the gasket, make sure it's intact and re-usable.Home Theater/2 Channel:
dhsspeakerservice.com/ -
By gasket, do you mean that there is a gasket (caulking?) in between the baffle and the speaker basket?Jesus said "I am the Way, the Truth and the Life. No man comes to the Father but through Me." - John 14:6
NAD 7140, Fried Model Qs, Pioneer PD-4700 -
I would hope there's something there to seal it. Could be fiber, foam, or rope caulk.Home Theater/2 Channel:
