sensitivity spec RTA 12C
soundfreak1
soundfreak1 Posts: 3,414
edited July 2014 in Vintage Speakers
Does anyone know the sensetivity rating on the RTA12C'S?
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • drumminman
    drumminman Posts: 3,396
    edited July 2014
    IIRC they're rated for as little as 10 wpc, all the way up to 500. Though you can get sound out of them with the lower number, they don't wake until you get past 100, in my case way past.
  • soundfreak1
    edited July 2014
    That im well aware of just curious If polk ever put a number on it like other manuf do ?
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Sea
    Sea Posts: 317
    edited July 2014
    I cannot find it right now but I am almost sure I have read 90db somewhere.
    Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
    Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
    Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
  • Nightfall
    Nightfall Posts: 10,086
    edited July 2014
    I think it's in the 90db to 92db range, and I'm pretty sure it's 92db.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • jon s
    jon s Posts: 905
    edited July 2014
    No... It's lower than that... According to the old Stereo Review magazine, the RTA-12 was tested at 87dB@ one meter/2.83 volts or one watt. I think the specs was about there as well...
  • Nightfall
    edited July 2014
    jon s wrote: »
    Which RTA12's, the originals?
    afterburnt wrote: »
  • drumminman
    edited July 2014
    From Audio Magazine annual equipment issue, 1987:
    SPL 1 watt @ 1 meter 92 dbl
  • westmassguy
    westmassguy Posts: 6,850
    edited July 2014
    The 12B was measured by Julian Hirsch, 1982 review. 87db SPL 1 meter, 2.83 volts @ 1,000 Hz.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • soundfreak1
    edited July 2014
    As much power as they need to have to really open up I would feel it has to in the low to mid 80's. I cant find it noted anywhere.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
