Sda 1B rdo-198 cross over mods Tl'd
Dusty B
Dusty B Posts: 28
edited July 2014 in Speakers
Who's done it, what crossover modification was done to make it happen. I haven't found anything exact in the archives.
Is it worth doing? over the drop in 194's. Any help advice or impressions from those who have done this would be appreciated.
  • Dusty B
    Dusty B Posts: 28
    edited July 2014
    Anybody have a link to this or any info? would like to see what it entails????
  • westmassguy
    westmassguy Posts: 6,849
    edited July 2014
    There is no TL mod for the 1B
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Dusty B
    Dusty B Posts: 28
    edited July 2014
    Ok, how about adding 5.8uf cap and running rdo 198's? Ive also heard that changing resistor value to 1.8 or 2 ohm
    i am interested in how this works more to the point if this works and still sounds balanced
    F1nut Posts: 52,406
    edited July 2014
    That would be the TL mod for the CRS+ and 2B. As westmassguy stated, "There is no TL mod for the 1B."
  • Dusty B
    Dusty B Posts: 28
    edited July 2014
    Thanks guys just wanted to make sure. ill just use the rdo 194 then. Anybody have an easily accessible list of components for the xover on the 1b's if not i will just pull it and take a look anyway. Maybe I will post a nice easy list of components for others if there isn't one.
    F1nut Posts: 52,406
    edited July 2014
    Schematics are posted in the vintage section.
  • Dusty B
    Dusty B Posts: 28
    edited July 2014
    ok ill check it out thanks again
  • Dusty B
    Dusty B Posts: 28
    edited July 2014
    whats up with this link here
    http://www.polkaudio.com/forums/archive/index.php/t-148147.html?
    where you talk about doing it? am I missing somthing....
  • tophatjohnny
    tophatjohnny Posts: 4,189
    edited July 2014
    Someone here did the mods u want to do, as I remember it was Shurkey??? I may be wrong? ?
    F1nut Posts: 52,406
    edited July 2014
    I wasn't talking about doing it. I was pointing out that without consideration for the second tweeter I don't think the frequency plot would look good and asked if anyone had plotted it, which no one has.
  • Dusty B
    Dusty B Posts: 28
    edited July 2014
    ahh I see. After reading into it a bit more it seems interesting in theory. Probably more trouble then its worth though. Does the 198 sound that much better than the 194? I don't have the opportunity to A/B them with out dropping the cash for both. One thing is sure the sl2000 is fatiguing and has a reported spike at around 13K "sounds lower then that to me though 8-10k range" probably the work of a sympathetic harmonic thing happening as it drops down into that more critical range. Just my guess.
    F1nut Posts: 52,406
    edited July 2014
    I'll say this, you will be very happy with the RD0194-1.
  • Dusty B
    Dusty B Posts: 28
    edited July 2014
    Good to hear, ill just go that route and redo the xover and focus on some of the other mods. Great forum here I appreciate everybody's comments and advice. Btw picked these up at good will for 10 bucks... always had my eye out for a pair. I cant loose on putting some cash into them no diminishing returns for me on these ones.
  • Dusty B
    Dusty B Posts: 28
    edited July 2014
    Im looking for two Mw 6509's if anybody has any lying around. I would rather use originals over the replacements. Lady at good will dropped one you can imagine what happened im sure.
  • westmassguy
    edited July 2014
    Dusty B wrote: »
    I asked the question, because my 2As were simple, single tweeter. The 1Bs are a different matter, and while Shurkey did put the 198s in, no one has measured or plotted the results. Progressive point sources are a different animal than single tweeters, as F1 suggested. They're your speakers to do with what you want.
  • tophatjohnny
    edited July 2014
    Dusty B wrote: »
    yeah. if I picked my 1B's up for 10 bucks I would do have my x overs done too!! I did however change to the 94's.Dynamat and installed Larry Rings, all which made noticeable improvements. Yes, this is a great forum, with great people. Some may come off harsh, so not for the thin skinned trolls for sure. I have come to really dig a lot of people and there is not anyone (regular members) I can say I don't like. So stick around and share your results, pics if ya are able to post them.
