Help me find a subwoofer for my setup... Polk Audio Monitor 70 fronts
shaun the
shaun the Posts: 1
edited July 2014 in Electronics
Hey guys. So Santa brought me a pair of Polk Audio Monitor 70 tower speakers, as well as their matching center channel, the CS2. I'd like to get some more deep rumble for movies. For music, just the tower speakers are good enough.
I'm thinking about the Parts Express SUB-1500, which seems to be the 15 inch version of their popular SUB-1200. While the SUB-1200 is highly reviewed, considering its price, the SUB-1500 has basically no reviews available anywhere. Going by the reputation of its smaller sibling, I'd assume that this is a good choice.
What else would you recommend?
__________________
ThinkPad T520 - srs bizniz
MacBook Air 11'' - iOS dev bizniz
1999 Mazda Miata - (street legal gokart on steroids!)
2002 Mazda Protege - (Work in progress)
Post edited by shaun the on
  • ken brydson
    ken brydson Posts: 9,005
    edited June 2014
    What's your budget? With subs, the sky is the limit....
  • AudioPro
    AudioPro Posts: 10
    edited June 2014
    I'm with Ken what's your budget?
  • quicksilvergts
    quicksilvergts Posts: 274
    edited July 2014
    I have exactly setup with the Polk PSW505 x2. Originally one though.
    Sounds great, very good match !! Well worth it for the cost for me. Can find real good deals on eBay.
    Next WILL be a SVS pb2000/pb12.
    But ultimately, it does boil down to "what's your budget"?
    Cheers,
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    Parasound 1200 II w/ Kimber Kable HERO + 4TC
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
    "If your BOLD enough to try it,
    your BOLD enough to make it happen"
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited July 2014
    In addition to 'What's Your Budget?' How big is your room and how much bass do you want/expect? If it's a massive room your budget may not get you the bass you're looking for. If it's a small room you may get more than enough.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
    tonyb Posts: 33,072
    edited July 2014
    I think that simple question threw "the Shaun" into a dizzy.
