Grill frames
Simplyrandom
Simplyrandom Posts: 119
edited June 2014 in Vintage Speakers
I was wondering if any of you had any success recreating grill frames for any of your projects. The 10a's I just purchased came with grills but both would need recovering and one has what appears to be water damage. The material is swollen at the bottom so badly it pushes the grill out. I am not so sure what material they are constructed out of. It almost seems as though they are layers of particle board which I assume might have been done to make them more rigid given there is very little material left in them on the sides especially where the cut outs for the mids are. I could of course experiment but I figure in my quest to achieve the 100 posts necessary to gain full access to the forums I would ask if any of you had any luck in this dept. I see them on ebay from time to time but I cringe to think how they would fair in transit.
Post edited by Simplyrandom on
