psw125 voltage
ag43
i've bought this sub from ebay. on the sub itself near the power cord is written "110v-240v". under the sub there's a sticker that's says "model:psw125 cherry 100v". which one is it? i'm form israel and i need 220V. can i safely connect it to the ac line or should i use a step down transformer? thanks.
Hello,
Welcome to Polk's forum. That subwoofer was made in two versions, a "domestic" 117V version and an "export" 220V version. Where was the unit you have shipped from, what country?
Regards, Ken -
usa.
here are pictures of the sticker and the voltage on the sub:
https://www.dropbox.com/sc/1xggr2jgwpec8a1/AADrAo9jFXbYHTgmxCUs93Dsa
https://www.dropbox.com/sc/jezlumaeaev4qc5/AABYEkKfiZDFnq-ZRZDLl_tZa -
Hello,
Let me check with Polk's CS department, some subs can be used with different voltages, but let me check to be sure.
Regards, Ken -
thanks!
Hello,
The PSW125 is not an auto-switching sub, you'll have to use it with a step down transformer.
Regards, Ken -
thanks anyway.
