DIY Cables
OleBoot
OleBoot Posts: 3,135
edited June 2014 in DIY, Mods & Tweaks
Anyone try any of the many DIY speaker cable recipes out there on the interweb with any success? Or have their own? Didn't come up with anything searching on here. I need some not horrible cable on a tight budget.
Post edited by OleBoot on
  • OleBoot
    edited June 2014
    Just got pointed to the Douglas Connection site in another thread - good stuff there and food for thought. Th PNF Audio site s giving me a cryptic message at the moment.
    EndersShadow Posts: 17,719
    edited June 2014
    OleBoot wrote: »
    Doug's a great guy. I suggest talking to him as he can customize the cables to be within your budget. That and he's a really cool guy. I've got a loaner set of his speaker cables and interconnects.
    I put his stuff on par with my Kimber Kable Hero interconnects & Kimber Kable 8VS speaker wire. And his stuff is cheaper :smile:.
    PNF Audio IIRC went under so your only going to find used stuff on the market.
  • george daniel
    george daniel Posts: 12,096
    edited June 2014
    Doug will sell you the raw cable--then you can diy,, highly recommended seller-- great guy to boot--I will have the opportunity of meeting him and getting a tutorial on cables this fall,,on my annual trek to the mountains of NC.
    Good luck!
  • OleBoot
    edited June 2014
    I'll definitely get in touch with Doug when I'm ready - just got to rebuild/refinish my Monitor 10s first, which will probably take quite some time as I tend to move slow :smile:.
    Just out of curiosity, anybody here have any opinions on this guy? http://www.geocities.ws/jonrisch/s2.htm
  • marvda1
    marvda1 Posts: 4,961
    edited June 2014
    he's a diy guru.
    Puritan PSM156
  • OleBoot
    edited June 2014
    marvda1 wrote: »
    he's a diy guru.
    Thought he might be. So anyone tried any of his Belden speaker cable recommendations?
  • Speedskater
    Speedskater Posts: 495
    edited June 2014
    Do they have to be good looking?
  • deafbykhorns
    deafbykhorns Posts: 150
    edited June 2014
    How long is your cable requirement?
    Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
    Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis
  • OleBoot
    edited June 2014
    Cables or DIY gurus? Cables no.
  • OleBoot
    edited June 2014
    For a 2 channel system, so stereo pair, maybe 8-10 ft each.
  • drumminman
    drumminman Posts: 3,396
    edited June 2014
    All my cabling is DIY, so these suggestions are from from personal experience.
    For speaker cables I built these: http://www.venhaus1.com/diycatfivecables.html They are fantastic, but . . . . . are fairly labor intensive and must be built using Belden (or some other teflon insulated) 1585A CAT 5 wire. The inner 8 wires are the ones that have to be teflon insulated as you discard the outer sheath. Imaging, transients, and smooth response across the frequency spectrum are the outstanding qualities it brings to my system.
    For IC's I built his Finesilvers, the recipe can be found here: http://www.venhaus1.com/diysilverinterconnects.html. These are astonishingly good. I built mine with Eichmann silver bullets and 32 awg teflon insulated wire I bought from McMaster-Carr. Materials cost was around $175 IIRC.
    Jon Risch is a well respected DIY guru, but from the posts I've read where folks have tried both his and those of Chris VH, the Venhaus recipes are better. The only Risch cable recipe I've built is an IC I use for my subwoofer. It's good, but I've only compared it to some cheaper AR IC's, which it easily bested.
  • OleBoot
    edited June 2014
    drumminman wrote: »
    I've seen a few recipes out there using CAT5, and they've always interested me - never seen this one before, and it does look intricate and, yes, time consuming. Definitely something to add to my when I retire list (not long now!). At the moment, however, I am looking for some sort of economical but not too horrible solution for some Monitor 10s I am just about to embark on rebuilding. I was looking at Risch's recommendations on off the shelf Belden coaxial. I've never used coaxial for speaker cable before, and wondered if anybody here had.
  • voltz
    voltz Posts: 5,384
    edited June 2014
    Audio Advisor has many no thrills AQ cables that they terminate how you want them. the type 4 at 8' pair cost $109 and the type 8 8' pair about $200. they have type 2 - rocket 33's etc..
    I used the rocket 33's with my RTiA7's, but I just got some Monitor 10's and will probably have Doug make my cables this time when I figure out what I need.
  • OleBoot
    edited June 2014
    Thanks, All. Lots to think about!
  • deafbykhorns
    edited June 2014
    I like good ole welding cable, #6 with a 150 or so strands. Its like bolting the amp to the back of your speaker.
    Dress it up with some cool wrap and you have yourself some nice cables.
