Looking to buy high quality speaker cables. Do you have what I need?
ROHfan
ROHfan Posts: 1,014
edited June 2014 in 2 Channel Audio
After purchasing Face's Mapletree Line 2A (thanks for the suggestion, bobsauto49) I have begin upgrading all my cabling. l This thing has taken my 2 channel listening to a level which I never thought possible. The only thing left is to get a good high quality speaker cable (6-8 feet), of which I would need two pair. I would prefer one side to have spade plugs and the other side to have locking banana plugs. I know I can just order some on Amazon but would rather give my money to someone here on the forum. Would like to keep the cost to around a Benny. I would consider custom built cables. Used cables should show no sign of wear. Thanks!
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
  • BlueFox
    BlueFox Posts: 15,250
    edited June 2014
    Can't help you, but I am curious why one side needs spades, and the other bananas. I doubt if many people have a pair like that, but some vendors do offer the ability to adapt the end to whatever you need.
  • ROHfan
    ROHfan Posts: 1,014
    edited June 2014
    BlueFox wrote: »
    My Martin Logans cannot accept spades, just Banana plugs, pins, or bare wire. The spades will connect to the amp so I can get it closer to the wall.
  • BlueFox
    edited June 2014
    Okay. I understand. Duh. :smile:
  • ROHfan
    ROHfan Posts: 1,014
    edited June 2014
    Somebody's got to have a set of speaker cables lying around, right? Hook a brother up.
  • ratster
    ratster Posts: 324
    edited June 2014
    Check out Clear Day cables. Paul is great to deal with and will send you a set to audition before laying out any money.
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Clear Day dbl.shotgun
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
    Clear day dbl shotgun
  • ROHfan
    ROHfan Posts: 1,014
    edited June 2014
    ratster wrote: »
    What would you take for them and what's with the battery things?
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2014
    I have a pair of MIT's? $5250 or I have a pair of wireworld silver eclipse 3 meters. I also have some apolloav speaker cables that arevery well made and soundgreat for cheap.
    edited June 2014
    High quality cables....for 100 bucks....with exact terminations no less, somebody better shake you to wake you up. LOL.
  • ROHfan
    ROHfan Posts: 1,014
    edited June 2014
    Dskip, how much would you take for them?
    gudnoyez Posts: 8,174
    edited June 2014
    Only a tad more than what the OP wants to spend, perhaps he will sleep on it.
  • B Run
    B Run Posts: 1,888
    edited June 2014
    Man I have the exact same speakers and just got some MIT Avt 2's and they sound awesome with the ESL's. I started a thread a while back and had lots of good info and opinions on cables. For your price range if you don't find anything used check out Signal Cables, that's what i'd get for the $.
  • ROHfan
    ROHfan Posts: 1,014
    edited June 2014
    tonyb wrote: »
    High quality to me is not necessarily high quality to you. I just went on the Blue Jean site and put together two pair of 500UP cables with 25 degree spades on one side and locking bananas on the other side. All for $143. And they're going to be ultrasonically welded.
  • ROHfan
    ROHfan Posts: 1,014
    edited June 2014
    You are on the crack thinking I'm buying the MITs. What are you asking for the apolloavs and do you have any pics?
  • ken brydson
    ken brydson Posts: 9,027
    edited June 2014
    gudnoyez wrote: »
    He'll ship them, uninsured, to the wrong address. Should be a great adventure...
  • ROHfan
    ROHfan Posts: 1,014
    edited June 2014
    I think I changed my mind and may be getting four of these. What do you all think? Of course, they are the single wire variety.
    http://signalcable.com/classicspeaker.html
  • marvda1
    marvda1 Posts: 4,963
    edited June 2014
    give forum member doug a call for custom cables.
    http://www.douglasconnection.com/
    Puritan PSM156
    F1nut Posts: 52,020
    edited June 2014
    Like I said before, sign up for the MIT cable demo program. At least they will give you a bench mark.
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited June 2014
    A hundred bucks is a lot of money for a couple of strips of wire. Having said that, I've done it. I bought a pair of Signal Cable Ultra speaker cables for just over a hundred. They look nice and Frank will terminate them to your specifications. He even gives a Club Polk discount of 5%. Highest recommendations if you're in the market for designer cabling that's built to last.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • OleBoot
    OleBoot Posts: 3,135
    edited June 2014
    tonyb wrote: »
    So, have you always been rich? Have you listened to the cheaper options? What do us "financially embarrassed" folks do? Give up all hope of thinking that we can get a system together that allows us to enjoy the music?
  • 11tsteve
    11tsteve Posts: 1,166
    edited June 2014
    OleBoot wrote: »
    and by your post count and join date, I am going to guess you don't really know the folks around here or their sense of humor.
    tonyb is one of the best, a stand up individual who worked with me exhaustively to purchase a VERY nice set of IC's with little risk and a super great deal.
    The OP DOES ask for a lot for $100...... but tony isn't trying to belittle him or anyone else in the same spot.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • ROHfan
    ROHfan Posts: 1,014
    edited June 2014
    I wound up going with Audio Advisor cables. 8', spade/banana. $137 with 3 day shipping.
    edited June 2014
    OleBoot wrote: »
    Oh geez...
    No, I certainly wasn't belittling anyone and spending more than 100 bucks doesn't determine one must be rich. Simply put, given the OP's gear list, I believe he could benefit from better cables. However, what the man decides on his up to him, no skin off my nose. As long as he likes what he hears, who gives a rats arse.
  • OleBoot
    edited June 2014
    tonyb wrote: »
    Oh geez...
    Sorry, five posts and I'm taking a pop at the regulars on here. One glass of Chateau de Plonque too many. The reason I snapped is that I am currently trying to get the readies together to redo some Monitor 10s I got quite a few months back and forgot to budget for cables, so $100 sounds like a lot at the moment when tacked on to the rest of the expense. Thinking of something DIY. Will ask for some opinions in the DIY forum. BTW, good to see that they spell arse correctly in Chicago (I'm English)
  • Hermitism
    Hermitism Posts: 4,338
    edited June 2014
    OleBoot wrote: »
    Wine in a box is your answer. Think of all the money you'll save and can apply towards a cable purchase. :smile:
    Canare 4s11 gets high praises around here for getting your feet wet in DIY speaker cables. My first (non-clearcoat) cable purchase was a used set of Belkin Pure AV cables. I spent little money but was able to hear a difference, before deciding on spending more money on even better cables.
    edit: Also, Doug from Douglas Connection (mentioned above) sells DIY cables by the foot and gives a discount to Polk forum members.
  • OleBoot
    edited June 2014
    Hermitism wrote: »
    Wine in a box? I'd stop buying food to eat before that !
    So I have been searching all over here for info on DIY cables, and manage to miss the reference to the Douglas Connection site in a thread I reply to. Just had a quick look, and looks really interesting - broad price range and all the required parts in one place.
  • Hermitism
    edited June 2014
    You get great customer service with Doug. He'll answer any questions you have.
    helipilotdoug is his username here on the forum.
  • Hermitism
    edited June 2014
    Doug sells Canare 4S11, but I'm using his Furez wire. I had complained about how bad my speakers sounded at a low volume because a lot of times I just like to chill listening to music at a low to moderate level. The one thing that really stood out about the Furez 12AWG/4 Conductor wire is how much better the music sounded at the lower volume levels that I listen to. I would always slowly raise the volume knob until it sounded good and then look at what number the volume knob was on after. And with the Furez, I saw that I wasn't having to raise the volume as high. It also seemed to bring out more detail in the music. I should mention I have very little experience in trying out different types of cables, so I'm only speaking from my own experience, but I'm very pleased with my choice and it was at a price point I didn't feel comfortable exceeding.
    edited June 2014
    OleBoot wrote: »
    It's all good, no harm no foul.
    BTW- we do a lot of things in Chicago....mostly wrong, spelling being one of those. We also tend to run words together, like "whatsamatteru" and "forgetaboutit".
    Given you have Musical Fidelity gear, I would make the same comment to you. Your gear deserves better...bluntly put. Kinda like putting fiberglass tires on a Mercedes....no ?
    I'm somewhat of an old **** myself and no stranger to being on a budget, bang for your buck, and all around cheap arse. Speaker cables are a matter of personal preference, the Canare mentioned earlier is about the best sound quality per buck you'll find. If you buy used, you can expand your options. Good luck on the Polks and enjoy your tunes.
  • Hermitism
    edited June 2014
    tonyb wrote: »
    Dude, you're in the mafia!
