VTL compact 100 mono blocks
Jhayman
Jhayman Posts: 1,548
edited June 2014 in 2 Channel Audio
I can get a set of these all redone and tubed for $1400
Now I'm 99% sure I'm am getting the Casta Model A speakers, 98db and only 18w
I believe these monos would drive them very nicely but can anyone shed some light on these blocks, are they even any good, reviews seem to say yes very good, but I'm looking for advice for my friends here, which I value your opinions very muc.
Can also get a set of Carver Black Beauty 305's in amazing shape for $5000..
I'm sure they would be better but basically Asing for John to pipe up here on these..
Also a VTL 5.5 preamp for a good price....
Thoughts are welcome..
Post edited by Jhayman on
  • madmax
    madmax Posts: 12,434
    edited June 2014
    Seems a little high. I see Manley signature reference series monoblocks 200W tetrode/100W triode (switchable) for $1800-2000 in great condition now and then. I use a pair on my Duos which are 104 db and there is no noise or troubles.
    Vinyl, the final frontier...
    F1nut Posts: 52,104
    edited June 2014
    Those VTL's are sweet amps, they use Mercury Magnetics transformers. The price does seem a bit high (not much) for stock versions, but considering they have been redone I would say it's a good price. The Carver amps are also very nice. You couldn't go wrong with either, IMO.
    The VTL 2.5 sounds better than the 5.5 to my ears.
  • george daniel
    george daniel Posts: 12,096
    edited June 2014
    There is magic in the vtl compact mono's,,, I used to own a pair,,,where are the bias pots located?
    If you get them,,do not skimp on the input tubes,, when dialed in properly,,they are fooking magic
    the pair that I had were the older version with the internal bias measurement points,,, be very careful here,,the more desirable ones had the external bias pots,, they do hold a steady bias though,, I miss mine dearly,, my brother has a pair of the vtl 100's,, and is very happy with them,,knowing what I know now,,I would say if the trannies are good,,then you will be a happy camper,,btw,,I paid 1k for mine years ago,,
    Good luck,,keep us posted.
    F1nut Posts: 52,104
    edited June 2014
    I thought you might chime in George. :cool:
  • george daniel
    edited June 2014
    Oh,,yeah,,one more thing,,, don't eff with the master bias ,, each tube has it's own adjustment,,play with that awhile,,when you get comfortable,,the master bias will be your friend,, I saw heaven once while tweaking the master bias, , most of all have fun.
  • Jhayman
    edited June 2014
    Thanks for the advice guys you sound like you like them, which is good for me..:cheesygrin:
    Here's the add for them I was over at his house earlier and listened to the Casta's again, I like very much..
    He said I could buy the VTL's for $1400 and when he gets in his shipment of Integrated Melody Amps I can use full trade in value towards a Melody..
    http://www.canuckaudiomart.com/details/649129956-pair_of_vtl_100_watt_compact_mono_blocks_see_photo/
  • Jhayman
    edited June 2014
    Thanks DSkip ..
    I was looking at those before but never pulled the trigger, but I did mention the Shuguang to him he tends to steer clear of stuff made in China..
    DSkip wrote: »
    Check this out at least:
    http://shop.grantfidelity.com/FACTORY-CLEARANCE-Shuguang-S300I-Integrated-Tube-Amplifier.html
    This could also be a contender for an integrated. While not SET, it is, by all accounts I've seen, a very sweet sounding little amp. I've had my finger on the trigger of this little bugger more times than I'd like to admit.
    http://www.usaudiomart.com/details/649128395-sophia_electric_baby_amplifier_located_in_vancouver_canada/
    A higher budget should obviously out-do these, but it might be enough to dip your feet in and see how far you want to take it.
  • marvda1
    marvda1 Posts: 4,964
    edited June 2014
    melody??? china!!!
    Puritan PSM156
    txcoastal1 Posts: 13,519
    edited June 2014
    marvda1 wrote: »
    melody??? china!!!
    Actually Australia...by a Chinese guy
    Chinaussie???
  • Jhayman
    edited June 2014
    I does not matter now anyways as I'm getting the VTL's for the time being and if I'm Happy with them I keep them and no Melody for me..
    I don't know enough about the company other than there made in Australia..
    He says what he likes is the Quality Transformers they use in their products..
    http://www.melodyamplifier.com/?page_id=274
  • george daniel
    edited June 2014
    Looks like it has the B+ fuse..I can see the bias adjustment pots,, but not the bias points,,you may have to pull the bottom cover off to measure,, yuo will have to turn the amp on it;s side,,and be very careful here,, alot of volts inside.
    edited June 2014
    I don't think you will be disappointed
    As for Melody, they are a top notch manufacturer as I own one and know the US distributor very well. Have had the opportunity to listen to most of their line
    edited June 2014
    DSkip wrote: »
    .... butt thats not to say where you end up won't be a good place either.
    He will be able to change speakersas needed
    F1nut Posts: 52,104
    edited June 2014
    You can use 6CA7's in the VTL's, which have more balls than the EL34's. Remove the cage support bars, the amps look better without them.
    F1nut Posts: 52,104
    edited June 2014
    :lol::lol::lol:
  • Jhayman
    edited June 2014
    Thanks guys they are coming today along with my Casta Model A's and possibly a VTL 5.5 if I desire or I can just use my McCormack LD-2 but like Bluefox he's really pushing the Audience power conditioner with the Teflon caps ..
    Jesse I'll take the cages off try to find 6CA7's..
    I'll post a few pics later on after I get my basement sorted out.
    F1nut Posts: 52,104
    edited June 2014
    You want the Treasures.
  • Jhayman
    edited June 2014
    Sorry Jesse are these 6CA7's called The Treasures or is it a specific brand?
  • george daniel
    edited June 2014
    That's a start,, he is gonna need 8 total,,another tube that plays well with the compacts are the older nos sed winged c el 34
  • george daniel
    edited June 2014
    Eh,, my experience with the Shuguang Treasure series has been extremely positive,, and they are manufactured in China. Hell of a good tube.
    Maybe I'm missing something here.
  • Jhayman
    edited June 2014
    DSkip wrote: »
    You don't want them. They're Chinese....
    By Golly you're Right..
    At least I can't let him know I bought them, lol
    Oh system all put together sounds very nice, have a few new speaker cables and power cords in the mix so letting them burn in..
