Amp suggestions/ setup?
lfink
lfink Posts: 2
edited May 2014 in Speakers
Hi I'm pretty new to this whole thing, so I have some questions about what to buy and what's good. Anyways, my previous system was simply comprised of 2 TSi300 speakers and a Pyle 2x120W Power Stereo Amp. I bought a PSW 110 sub and I'm not exactly sure how I should change the system to accompany it. I'm looking for something in a similar price range and complexity range.
Thanks!
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited May 2014
    The easiest way to integrate the sub with your system as is would be to use the high level, or speaker level inputs which look like speaker cable connections on the back of the subwoofer. Then run speaker cables from the subwoofers speaker level outputs to the speakers.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • lfink
    lfink Posts: 2
    edited May 2014
    So I would keep the same amp and incorporate the sub through the speakers?
  • Inspector 24
    edited May 2014
    Yes. Here's an example of how that would look.
    http://cdn.avsforum.com/8/82/82d3fd6d_vbattach89652.jpeg
    Up
    Down
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited May 2014
    You could also look at something like the Yamaha R-S300, which is a stereo receiver with a subwoofer output.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
