Worth it or not?? Rear surrounds upgrade?
Sweets10v8
Sweets10v8 Posts: 73
edited May 2014 in Speakers
Recently picked up a CSi5, and now only my rear surrounds are not RTi matched. I currently have Monitor 50s and am thinking of selling them to pick up a pair of RTi6s.
Is it worth the.hastle since the rears seem to output so little?
Man cave:
120" screen
Epson 8350 projector
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
Rears: Monitor 50s
  • chumlie
    chumlie Posts: 8,658
    edited May 2014
    Get another keg. Rears are fine IMO.
  • Mystery
    Mystery Posts: 2,546
    edited May 2014
    Rears are not as critical as fronts but it's better to match all around.
    If you have the money, why not?
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited May 2014
    Rears are very important and must be matched with the correct line that you use. If your in a smaller room and only doing a 5 ch setup with rti then you must must must get fxi's.
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited May 2014
    im willing to bet many here have mismatched systems and i'll also bet they're pretty in tune. its all about how much time you put into set up and room treatments and such.
  • polkfarmboy
    edited May 2014
    No your wrong its not in tune, if many have it like this its because they dont care or have never heard a properly balanced timbre matched setup with good source material.
  • recoveryone
    recoveryone Posts: 930
    edited May 2014
    PFB has a point if you are looking at the specs of the fronts, center and rears. You ideally want matching speakers for the propose of being able to better make adjustments in room treatments and speaker placement. Ohms, power rating, SPL level and crossovers. Each brand or even each series line can differ and cause havoc on your listening enjoyment.
  • seabeerob213
    edited May 2014
    im not saying he is wrong, im saying that there are non timbre matched speakers out there that can be made to sound awesome in a system. how many people here use subs that arent timbre matched, or upgrade their speakers with different drivers that arent timbre matched. while we're at it, all of our electronics must be same brand, and series too; cables and connectors need to be the same brand, right?
  • recoveryone
    edited May 2014
    The more you can match, makes it easier to find the sweet spot or find the flaws.
  • blehmbo
    blehmbo Posts: 179
    edited May 2014
    If you aren't happy with the monitors as rears then try something else. Some will say matched rears is crucial, some will say it isn't too important. It all really comes down to how satisfied you are with your rig in its current state, and how much funding you have.
    I just run a 3ch setup with the subwoofer crossover set roughly to where my lsim703s cut out. Center is a lsic, not a perfect match for the lsim703s, but the lsim706c isn't a priority upgrade for me at this point.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited May 2014
    Well they look nicer, it would be superb if you can find a merchant with a generous return policy.
    Please post back your findings / opinions if you do this.
  • westmassguy
    westmassguy Posts: 6,849
    edited May 2014
    My stuff is all vintage, but I have to agree, timbre matching across the front is critical, front to rear less so, but still very important, especially with well engineered surround tracks. Nothing more aggravating than vocals or effects changing while panning.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Sweets10v8
    edited May 2014
    blehmbo wrote: »
    it's not that I'm not happy , always want to upgrade, but not enough funding for a pre amp.
    Man cave:
    120" screen
    4 Tap Kegerator
    Audio:
    AVR: Onkyo 818
    Sub: SVS 25-31 PCi
    Fronts: RTi 8s
    Center: CSi5
    Surrounds: FXi 30s
    Rears: Monitor 50s
