Panamax M5300-PM
Mikey081057
Mikey081057 Posts: 7,127
edited May 2014 in Electronics
Wanted one of these for awhile but didn't want pay $539 for one so I stuck with a Monster reference 2500 waiting for a deal on the Panamax.
Apparently these are going end of life, and I found one NIB for $329.
This unit has the right combination of switched and un-switched outlets (11 total) Phone, modem, cable sat coax filters and a usb charge port.
Very well designed and will protect and or power down your devices when when power gets squirrely.
The front panel meters are handy and nice, and canned be dimmed/turned off...
Sweet deal... If you are looking for one of these the features/protection are now available at a nice price point.
Garage | Polk Monitor 5B's
Post edited by Mikey081057 on
  • Thorton
    Thorton Posts: 1,324
    edited May 2014
    That's a good price. I bought a demo a year ago for around that price.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • steveinaz
    steveinaz Posts: 19,546
    edited May 2014
    Panamaxs' stuff is nice, but man it is getting pricey.
  • BlueFox
    BlueFox Posts: 15,250
    edited May 2014
    I have a couple of Panamax units, forgot the numbers, before I replaced them with Shunyata gear. I know for a fact they work with detecting low voltage, and shutoff if the voltage gets below a certain level. However, one of the units has an amp meter on it, and I plugged my two Pass amps into to it to see how much current they drew at idle (8 amps on the meters). The problem is they hum a little bit with that much current going through them, and this was using the high current ports.
    msg Posts: 10,477
    edited May 2014
    congrats man, that's a great deal. I just got some Panamax stuff on similar deal, too, but mine is refurbed on trade-in on older failed P-max equip. can't really speak to any improvement of audio or video quality, but it sure looks cool, and I at least feel better protected :)
  • bayni7
    bayni7 Posts: 15
    edited May 2014
    I also have a Monster reference 2500 and I'm looking to upgrade. The price is pretty attractive too. Did you notice any performance increase with the Panamax?
  • Mikey081057
    edited May 2014
    bayni7 wrote: »
    My deal was that the Monster 2500 just didn't have enough sockets... I moved the monster 2500 to my 2 channel rig...I really don't notice any video or sonic improvements and didn't/couldn't do any side by side comparison.. it sure is a nice looking unit that I as sure is protecting my HT gear I now have my Directv and my ethernet being protected too..
  • BlueFox
    edited May 2014
    My experience is you need to move up the food chain before you get noticeable audio and video improvements. However, then you lose things like under voltage protection. I went from Panamax to Shunyata in both my two channel and HT. The audio, and video, improvement was more than obvious. However, the Shunyata gear only has a breaker for over current protection. They specialize in removing noise from the AC line, and recommend getting a whole house surge protector if you worry about that.
  • westom
    westom Posts: 45
    edited May 2014
    I really don't notice any video or sonic improvements and didn't/couldn't do any side by side comparison.. it sure is a nice looking unit that ...
    Did you read its numeric specifications? It is electrically equivalent to a $20 power strip with a fancy front display also provided by a Kil-A-Watt for $29.
    The term 'conditioner' has no technical significance. But it works on consumers who make decisions on feelings; not facts. Some conditioners actually claim some 'near zero' filtering. This one does not.
    BTW, Monster has a long history of identifying scams. Then selling an equivalent product for even higher profits. If Monster is selling an equivalent product, then suspect all are scams.
    Monster once sold speaker wire with ends marked for the amp and speakers. Reverse that wire (connect speaker end to the amp) and sound would be subverted - so said Monster. Then many consumers even claimed they could hear a difference. Monster sold this $7 speaker wire for $70. Because so many consumers just know from feelings and bogus (but expensive sounding) phrases. And routinely ignore the only place where Monster, et al cannot lie. The numbers.
  • recoveryone
    recoveryone Posts: 929
    edited May 2014
    I have the 5300-EX on my HT and a older 500 DBS on my 2ch setup. What I have notice on the 5300 is the use of the high current outlets, these are used for my AVR and SUB. I can tell a noticable improvement in both units in reserve power in the AVR and tighter bass in the sub due to a solid current feeding each of them. The 500 DBS made a big improvement in depth of sound and taking out some electrical feed back (pops) from appilances in the kitchen as both are on the same circuit in the house. I had power strips on both prior to switching.
  • deafbykhorns
    deafbykhorns Posts: 150
    edited May 2014
    Do you still get the insurance if purchased outside dealer network?
    Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
    Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis
  • mantis
    mantis Posts: 17,563
    edited May 2014
    the 5400 is where Panamax actually gets really good, just look over the spec's of the 2 and you might want to save up a few more pennies.
    Dan
