ClarityCap ESA 250V vs SA 630V ?
Aroundthesuond
Aroundthesuond Posts: 37
edited May 2014 in DIY, Mods & Tweaks
the ESA series 250v costs the same or less than the SA 630v series
what are your opinions?
thanks
Post edited by Aroundthesuond on
    pitdogg2 Posts: 27,065
    edited April 2014
    and the need for a 630v cap is what? Do you understand the size difference? If you have the space no problem but ask yourself do I have the room for a softball in there.....
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited April 2014
    Ive used both I prefer the ESA'S if for no reason than the size.. they sound great either way the sa's are just too huge for most applications.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Aroundthesuond
    edited April 2014
    Sincerely, I asked opinions only on ESA: 630v vs 250v
    than kyou
  • headrott
    headrott Posts: 5,496
    edited April 2014
    than kyou
    No, go back and read your original post. You did not ask for a comparison of Clarity Cap ESA: 630V vs. 250V
    Is the above what you meant to ask for though?
  • Aroundthesuond
    edited April 2014
    ops, sorry...my mistake
    is right my original post.
    in addition would be nice also your point of view about ESA 250v and ESAv 630 : are very different?
  • Aroundthesuond
    edited April 2014
    the ESA you used were 250V ?
    i'm referring to ESA 250 v series
    thank you
  • headrott
    edited April 2014
    No problem. Just wanted to clarify what you were looking for.
    I have only used the 630V ESA's, so I cannot directly compare them to the 250V versions. I would think that only the size would be different between the two voltages. I highly doubt they would sound different unless you tried to run too much voltage through the 250V versions.
  • Aroundthesuond
    edited April 2014
    well
    if we examine the 4.7uF:
    - SA 4.7uF 630v dim (35.0 x 46.0) = EUR 6.97
    - ESA 4.7uF 250v dim (25.0 x 33.0) = EUR 8.13
    ESAs 250v are far superior to SA 630v and only cost a little more
    So, are the ESA 250v recommended to SA 630v if you don't need 630v voltage ?
  • westmassguy
    westmassguy Posts: 6,850
    edited April 2014
    The ESAs are Clarity's High end Capacitor, aside from the MRs which are priced in the stratosphere. They are superior to the SAs.
    250 volt rated caps are more than enough. If you're recapping vintage Polks, the existing Mylars are rated 100 volt, and the Electrolytics are rated 50 volts.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Aroundthesuond
    edited April 2014
    so if i don't need 630v requirements, for a slightly higher price, the ESA 250v are a must, right ?
    question :
    but why claritycap has these two series (ESA 250v and SA 250v) almost at the same price but with more better performance for the ESA ?
    this is not clear to me.
  • westmassguy
    edited April 2014
    Clarity's line up, with increasing quality is: PX - SA - ESA - MR. Why the SAs and ESAs are that closely priced in the EU is anyone's guess.
  • Aroundthesuond
    edited April 2014
    could you explain better ?
    i think clarity know this
    thank you
  • westmassguy
    edited April 2014
    thank you
    Explain what? That's their line up. If you want more information on what differentiates the four different models, visit the Clarity Website: http://www.claritycap.co.uk/
    If you can't find what your looking for there, then contact them directly.
  • Aroundthesuond
    edited April 2014
    ok, thank you very much
  • Dallas21
    Dallas21 Posts: 3
    edited May 2014
    I have experimented with several capacitors including the old Auricap, and new Auricap XO, which is not that
    Much money and my last best value coupling ,capacitor,and for Xovers was the Obbligatto Gold.
    The new Series Auricap-XO has better top end extention dig a bit deeper in detail and Bass has a little more control.
    I was just having my Dared SL 2000A preamp completed only $140 for the 2-.22 input caps, and 4 -1.0 uf coupling caps
    I am even going to upgrade the resistors
    To a Mills type other improvements Hifi tuning 20 mm 3Aslow Supreme fuse, Herbies tender feet,and Titanium tube dampers
    And Signal cable makes a nice high purity awg12Copper,Teflon power cord for a $125.
    Tubes 6106-5y3 Bendix and Sylvanis 3 mica Gold series Black plates. I found a good electronics tech in Ma that redoes with all Mundorf Supreme solder like night and day when finished .my friend had his done last month. For less then $1,000
    Total including unit will easilly go toe to toe at 3X it's cost.
  • BKphoto
    BKphoto Posts: 409
    edited May 2014
    OP are you actually building something or just interested in cap specs...?
    BTW your name is still spelled wrong...
    Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
    F1nut Posts: 51,790
    edited May 2014
    I mentioned that to him before, which he didn't take kindly.
  • BKphoto
    BKphoto Posts: 409
    edited May 2014
    Ha....
  • Aroundthesuond
    edited May 2014
    i don't know how to correct my name !!!!
    F1nut Posts: 51,790
    edited May 2014
    I have contacted a moderator on your behalf to see about correcting your user name spelling.
  • Aroundthesuond
    edited May 2014
    thank you indeed
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited May 2014
    I'll have to ask Polk IT to do that, there is already a "AroundTheSound" user name so it might not work.
  • Aroundthesuond
    edited May 2014
    will be good also "Aroundthemusic"
