Crossover for LSI9
gene stangel
Any one know if replacement crossovers are available for the LSI9 from Polk and what the cost would be?
thanks
thanks
Post edited by gene stangel on
The easiest way to find out is to call them. They still had some for the LSiFx when I checked a couple months ago.
http://www.polkaudio.com/forums/showthread.php?128992-Vr3-Fortress-Edition-Mods
More expensive than the stock crossover, but worth it if you're having to replace them anyway.Things work out best for those who make the best of the way things work out.-John Wooden
