Polk sub or not...?
HDTVAV
HDTVAV Posts: 80
Are Polk subs any good?
Or should I be looking at a different brand?
Post edited by HDTVAV on
  • rpf65
    rpf65 Posts: 2,127
    edited April 2014
    Depends on what you're looking for.
    The PSW 505 is actually a very good budget sub, budget sub being under $500. You have to keep in mind that Polk is a speaker company that happens to make subs. Subs aren't their main focus, so get a little less attention.
    Want a good sub, go to a sub company. SVS, HSU, Power Sound Audio, and Velodyne make very good moderately priced models, $500 to $2K range. Velodyne DD series can be pricey, but they offer a quite a few moderately priced models. These are sub companies, SVS happens to be a sub company that makes speakers, for instance.
    Polk's DSW series are fairly good sounding subs. Never heard their Micropro series, but haven't heard of many complaints as far as performance.
    I have heard all manufacturers listed except Power Sound Audio and the Micropro. Just going by what I've read on those.
  • gonzo64
    gonzo64 Posts: 39
    edited April 2014
    i kinda heard this about polk too....i own a polk sub too...lol...but upgrading also....i heard hsu research is a good choice....im thinking of the stf-2 myself....
  • Conradicles
    Conradicles Posts: 6,376
    edited April 2014
    Nothing but glowing reviews about the polk micropro series. I want to try one in the future.
  • SDA1C
    SDA1C Posts: 2,072
    edited April 2014
    Micropro subs rock....try Sunfire or Velodyne for superior performance in a realistic budget. Look into the Deckware Home Wrecker if you can afford to play a bit and have the space to incorporate a new piece of furniture.
    Too much **** to list....
  • codyc1ark
    codyc1ark Posts: 2,539
    edited April 2014
    All good advice, but the most important question when sub shopping is what is the budget? Not much performance can be had in the $300ish range, but if your looking to spend $500 or perhaps more there are a TON of options...
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited April 2014
    So much depends on what cu.ft. of room space you're trying to pressurize. Many of us have an open floor design which combines the den, kitchen, living room and sometimes the rest of the house. I had to install an extra wall and doors to seal of my den (HT) from the rest of the house. I still had to pressure about 4000 cu. ft. To get good, clean, down to 20 hz. bass it's going to cost some extra bucks. I'm running 2 Epik Empire subs that cost me about $1800 total and I still would like a bit more low end. You're so right Cody, the budget is going to determine the amount and quality of bass you'll be satisfied with. To get good, quality bass down to 16 hz. will cost more, to get down to 8hz is really going to cost more. I'm not even sure if Polk makes a sub that can dig cleanly to 16 hz.
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited April 2014
    This needed repeated.
    rpf65 wrote: »
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited April 2014
    Got 2 mp3k's in my ht rig and they rock
    Garage | Polk Monitor 5B's
  • I went with SVS PB 2000. They are huge, btw...
  • K_M
    K_M Posts: 1,631
    We had the older PSW1000 sub and loved it, even though it was not the loudest or deepest bass sub overall, it has a Very clean musical sound, that was awesome on most music.
    Of course the amp went bad recently, as we have read many do, and it is a paper weight in basement now...lol
