Rta 15
nohalfstephen
Are RTA 15s any good? Someone offered me a pair for 400 bucks. Is it worth it? Sorry for all the threads.
Post edited by nohalfstephen on
RTA-15s, with the Dacato mod are outstanding, but 400 for stock is a bit highHome Theater/2 Channel:
dhsspeakerservice.com/ -
Maybe I could offer 300? They were originally asking for 500. What do you guys know about rta 8ts?
nohalfstephen wrote: »What do you guys know about rta 8ts?
What do you want to know?
Price? Around $125.
Won't have bass like the RTA-15's.
I guess what I am asking is what's the better buy? Here in Northeast Ohio we have no deals at all on vintage polk audio stuff. In order for me to get either the rta 15s or the rta 8ts I'll have to drive 3 hours or have them shipped.
I would think that a pair of Vgood/MINTY 15tl's would be worth that. But they would have to be in working tip top shape & condition would definitely have to be in very good condition. 8's are a great speaker also. the 15's will need alot of power to get the best out of them-so keep that in mind. Good Luck on your decision..
Edit
welcome to club polkRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
What speakers are you using now?
I'd not drive 3 hours unless I find the speakers I'm looking for or a great deal or if I need something now.
If the RTA15TL is too much, consider the RTA11TL. If you have placement constraints, the RTA15TL's can be an issue with the rear firing PR. The RTA11TL's are very placement friendly, much more so than my LSi15's. But still the RTA15TL is an excellent vintage Polk Audio speaker.Stan
Main 2ch:
HT:
Other stuff:
@Mystery, right now all I have are monitor 5s. I was recently given a Kenwood ka-701 integrated amp. Hence the reason I feel the need to have a couple more speakers. The setup is going in my living room which is 15x20. Thanks for everyone's suggestions.
I had a pair of 15's in my 16-24 living room & they did a excellent job. But like all vintage speakers they could be due for fresh internal parts in time. Keep us updated. Good LuckRandy-Maine
by David WMG
I just upgraded the 5B's in my home theater to a pair of 8TL's and I couldn't be happier. Don't get me wrong, the %b's are great speakers and I've enjoyed them since I bought them new in 1985. The 8TL's seem a very similar sound to the 5B's but with a smoother highend, a bit deeper lows, and slightly less strained mids. I like the 8TL's a lot! The 11's must be even better - enjoy!Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
Mains: 2x Polk RTA 8TL's
Center: Polk CS245i
Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
Rear Surr: 2x Polk M4a '90
Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
Display: Samsung 55" UNC55-8000 3D LED
Console: Xbox360
DVR: custom MythTV rig w/ 3 tuners OTA
Zone2: 2x Polk M5b '87 -
I have yet to hear the 15's but had 8TL and didn't care for them but RTA-11's are pretty decent.
I've got another question, how do the monitors and rtas compare to the sda line? I know that I'll have to hear them for myself, but as stated earlier, no one in Northeast Ohio is selling any kind of vintage speakers, let alone vintage Polk audios. But on the other hand someone is selling a pair of kappa 7.1 speakers.
Well shock and awe, I have the opportunity to buy a pair of sda 2b speakers in my area! I'm going to have a listen and check them out Friday. With those who already have these speakers, what are some things I should look out for before buying them?
Make sure you hook it to a Common Ground amp/receiver you should need at least 80wpc (i know it says 50 min) but ive tried 50-60wpc & they start clipping at 10-11:00 on the dial. 80wpc will make noise BUT will NOT make them sing. (Kinda like hauling a 28ft camper with a Ranger) it will work/but not well. get my point. The more quality power the better. 200wpc is a good place to START. & as stated above youll need the interconnect cord. SDA's are a great speaker. But do keep in mind that a 25 year old speaker may need refreshing parts-so open your wallet
they are (to me) a better sounding speaker than the RTA/Monitor. Placement plays a big part also. They need to be 6 feet apart & 6-8 inches off wall.. Each speaker should have 3 ft on each side of them..No toe on these SDA's..... You wont need a subwoofer unless your into heavy bass.. Great speaker. Good choice. Randy-Maine
by David WMG
Thanks boston1450 and nbrowser! The guy selling these speakers said he did the dynamat mod on all the speakers. What exactly is that and will it affect the sound?
I myself have not upgraded either of my SDA's. I have had other issues in the last year with our daughter's health. I hope to do it in the near future. They sound very good to my ears now & sure they will be better when they do get done. Im sure others will chime in on what those upgrades will do-or look/search here & youll find alot of info.Randy-Maine
by David WMG
Dynamat on PRs and WoofersHome Theater/2 Channel:
Thanks guys! I'll keep you posted!!
Well, back to the hunt.... Anyone know of any Vintage Polk speakers being sold in Ohio?
Just picked up a pair of SDA 2s. As I was doing some searching on what is required to run these speakers, I had a couple of questions. I read that theses speakers needed a common ground amp to run them,I'm not sure if the Kenwood ka-701 is a common ground amp. If so will it be good enough to power them efficiently? It has a rating of 80 watts per channel @ 8ohms.
Which SDA-2s? The original 2s, and 2As are 4 ohm speakers. The 2Bs are 8 ohm compatible.Home Theater/2 Channel:
They're the 2As. If they were the 2B speakers it would say on the back right?
Maybe, maybe not. Are there two or three woofers? Is the interconnect cable blade/blade, or pin/blade?
A standard 2B has wrap-around grill, with slab top and bottom. 2B Studio version looks similar to the 2/2A, front grill with walnut vinyl.Home Theater/2 Channel:
Two woofers, pin and blade.
It's a 2BHome Theater/2 Channel:
So is a common ground amp still needed? Is 80 watts sufficient?
Common ground is needed, and the 80 watts will make noise, but not shake the house. The amp supposedly is rated for use with 4-16 ohm speakers, but it's really not going to power them properly, especially if you like your music loud, and like a lot of bass.Home Theater/2 Channel:
remember you are on a site where everyone here has driven at least that long for something we weren't quite sure we wanted...its called crazy...! its a good crazy, but still...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
Whew! I'm glad I only drove 2 hours! Any suggestions on what amp to use?
Adcom GFA 555/555 II are very popularHome Theater/2 Channel:
